I have used 24 seven segment displays using multiplexing (74HCT595 & ULN drivers) successfully. Now I have to build a board having 48 & 75 displays in two parts. My question is whether a single arduino is capable of driving this number of displays (without flickering)? All the displays are 0.56" size.
I can use MAX7219, but they are quite costly, and one chip supports only 8 displays. Whereas I can get arduino nano or pro mini at the price of single MAX7219. If I can know maximum number of displays a single MCU can handle, I can break the displays in parts.
If all digits are completely refreshed every 4mS or so, then there should be no noticeable flicker to the human eye.
But how did you organise the 24 displays ? As one long chain of 595s or did you split it ?
There are also different multiplexing strategies such as one digit with all needed segments lit each cycle, or 1 segment with all digits using that segment lit each cycle.
Maybe a quick diagram of what you have already got working would be good.
Incidentally, some Ebay retailers have Max7219 / Max7221 chips around $1 each and this would mean less soldering (only 1 current limiting resistor per chip)
You can get cheap (possibly counterfeit) MAX7219-like chips from the same sources that sell cheap nanos and pro-minis. Like https://www.aliexpress.com/item/32875328547.html - I have no idea how trustworthy or operational those are.
I had cascaded 6 number of 595s & they were used to drive 6x4 matrix of the displays. The microcontroller used was 89S52 with 11.0592Mhz crystal. It was running very smoothly.
Anyway, I have decided not to use multiplexing as the available PCB space is limited and required peak current will be very large, it is described in this link. https://www.avrfreaks.net/forum/how-many-7-segment-digits-can-you-multiplex
Thanks everyone for your replies. @Paul_B I am getting original MAX7219 and arduino nano or pro mini at ₹200 here in India. But, chinese version of MAX7219 is available at ₹95. @westfw I had used earlier cheap MAX7219-like chips without any problems, so I will continue with them. TM1637 is also a good option ₹35, but it can only drive 6 displays & cannot be cascaded (I think), so it will need more number of MCU pins. Thanks!
