maximum pot value for ADC
What or where am I looking in a datasheet to determine the maximum and minimum values that a pot connected to a uC ADC can be.
Since the pot is connected to 5volt/GND, a constant current is flowing through the pot.
If pot value is too low, it will heat up the pot (they do have a max power rating).
100-500ohm could be a minimum value, depending on pot size.
10Megohm is about the practical upper limit. Above that you will have problems with hum/hash/leakage.
But there is also cross-talk to consider if you're using more than one pot.
Therefore we recommend 10k linear.
Leo..
This youtube video shows different value pots used.
Unfortunately the guy doesn't know about cross-talk.
