MaxRefDes117 Arduino Code Error
Hi all, beginner Arduino user here.
I recently bought the Maxrefdes117 board (which includes the Max30102 Pulse Ox Sensor) and an Arduino UNO and I’m planning on getting them working. I downloaded the Arduino IDE and the source code form the Maxim website but when I tried to compile it I am getting numerous errors.
This is the code
** \file RD117_LILYPAD.ino ******************************************************
* Project: MAXREFDES117#
* Filename: RD117_LILYPAD.ino
* Description: This module contains the Main application for the MAXREFDES117 example program.
* Revision History:
*\n 1-18-2016 Rev 01.00 GL Initial release.
*\n
* This code follows the following naming conventions:
* char              ch_pmod_value
* char (array)      s_pmod_s_string[16]
* float             f_pmod_value
* int32_t           n_pmod_value
* int32_t (array)   an_pmod_value[16]
* int16_t           w_pmod_value
* int16_t (array)   aw_pmod_value[16]
* uint16_t          uw_pmod_value
* uint16_t (array)  auw_pmod_value[16]
* uint8_t           uch_pmod_value
* uint8_t (array)   auch_pmod_buffer[16]
* uint32_t          un_pmod_value
* int32_t *         pn_pmod_value
/*!\mainpage Main Page
* \section intro_sec Introduction
* This is the code documentation for the MAXREFDES117# subsystem reference design.
*  The Files page contains the File List page and the Globals page.
*  The Globals page contains the Functions, Variables, and Macros sub-pages.
* \image html MAXREFDES117_Block_Diagram.png "MAXREFDES117# System Block Diagram"
* \image html MAXREFDES117_firmware_Flowchart.png "MAXREFDES117# Firmware Flowchart"
#include <Arduino.h>
#include "algorithm.h"
#include "max30102.h"
//if Adafruit Flora development board is chosen, include NeoPixel library and define an NeoPixel object
#if defined(ARDUINO_AVR_FLORA8)
#include "adafruit_neopixel.h"
#define BRIGHTNESS_DIVISOR 8  //to lower the max brightness of the neopixel LED
Adafruit_NeoPixel LED = Adafruit_NeoPixel(1, 8, NEO_GRB + NEO_KHZ800);
#endif
#define MAX_BRIGHTNESS 255
#if defined(ARDUINO_AVR_UNO)
//Arduino Uno doesn't have enough SRAM to store 100 samples of IR led data and red led data in 32-bit format
//To solve this problem, 16-bit MSB of the sampled data will be truncated.  Samples become 16-bit data.
uint16_t aun_ir_buffer[100]; //infrared LED sensor data
uint16_t aun_red_buffer[100];  //red LED sensor data
#else
uint32_t aun_ir_buffer[100]; //infrared LED sensor data
uint32_t aun_red_buffer[100];  //red LED sensor data
#endif
int32_t n_ir_buffer_length; //data length
int32_t n_spo2;  //SPO2 value
int8_t ch_spo2_valid;  //indicator to show if the SPO2 calculation is valid
int32_t n_heart_rate; //heart rate value
int8_t  ch_hr_valid;  //indicator to show if the heart rate calculation is valid
uint8_t uch_dummy;
// the setup routine runs once when you press reset:
#if defined(ARDUINO_AVR_LILYPAD_USB)
  pinMode(13, OUTPUT);  //LED output pin on Lilypad
#endif
  //Initialize the LED
  LED.begin();
  LED.show();
#endif
  maxim_max30102_reset(); //resets the MAX30102
  // initialize serial communication at 115200 bits per second:
  pinMode(10, INPUT);  //pin D10 connects to the interrupt output pin of the MAX30102
  maxim_max30102_read_reg(REG_INTR_STATUS_1,&uch_dummy);  //Reads/clears the interrupt status register
  while(Serial.available()==0)  //wait until user presses a key
    Serial.write(27);       // ESC command
    Serial.print(F("[2J"));    // clear screen command
    Serial.println(F("Lilypad"));
#endif
    Serial.println(F("Adafruit Flora"));
#endif
    Serial.println(F("Press any key to start conversion"));
  uch_dummy=Serial.read();
  maxim_max30102_init();  //initialize the MAX30102
// the loop routine runs over and over again forever:
  uint32_t un_min, un_max, un_prev_data, un_brightness;  //variables to calculate the on-board LED brightness that reflects the heartbeats
  int32_t i;
  float f_temp;
  un_brightness=0;
  un_min=0x3FFFF;
  un_max=0;
  n_ir_buffer_length=100;  //buffer length of 100 stores 4 seconds of samples running at 25sps
  //read the first 100 samples, and determine the signal range
  for(i=0;i<n_ir_buffer_length;i++)
    while(digitalRead(10)==1);  //wait until the interrupt pin asserts
    maxim_max30102_read_fifo((aun_red_buffer+i), (aun_ir_buffer+i));  //read from MAX30102 FIFO
    if(un_min>aun_red_buffer[i])
      un_min=aun_red_buffer[i];  //update signal min
    if(un_max<aun_red_buffer[i])
      un_max=aun_red_buffer[i];  //update signal max
    Serial.print(F("red="));
    Serial.print(aun_red_buffer[i], DEC);
    Serial.print(F(", ir="));
    Serial.println(aun_ir_buffer[i], DEC);
  un_prev_data=aun_red_buffer[i];
  //calculate heart rate and SpO2 after first 100 samples (first 4 seconds of samples)
  maxim_heart_rate_and_oxygen_saturation(aun_ir_buffer, n_ir_buffer_length, aun_red_buffer, &n_spo2, &ch_spo2_valid, &n_heart_rate, &ch_hr_valid);
  //Continuously taking samples from MAX30102.  Heart rate and SpO2 are calculated every 1 second
  while(1)
    i=0;
    un_min=0x3FFFF;
    un_max=0;
    //dumping the first 25 sets of samples in the memory and shift the last 75 sets of samples to the top
    for(i=25;i<100;i++)
      aun_red_buffer[i-25]=aun_red_buffer[i];
      aun_ir_buffer[i-25]=aun_ir_buffer[i];
      //update the signal min and max
    //take 25 sets of samples before calculating the heart rate.
    for(i=75;i<100;i++)
      un_prev_data=aun_red_buffer[i-1];
      digitalWrite(9, !digitalRead(9));
      //calculate the brightness of the LED
      if(aun_red_buffer[i]>un_prev_data)
        f_temp=aun_red_buffer[i]-un_prev_data;
        f_temp/=(un_max-un_min);
        f_temp*=MAX_BRIGHTNESS;
        f_temp=un_brightness-f_temp;
        if(f_temp<0)
          un_brightness=0;
          un_brightness=(int)f_temp;
        f_temp=un_prev_data-aun_red_buffer[i];
        un_brightness+=(int)f_temp;
        if(un_brightness>MAX_BRIGHTNESS)
          un_brightness=MAX_BRIGHTNESS;
      analogWrite(13, un_brightness);
#endif
      LED.setPixelColor(0, un_brightness/BRIGHTNESS_DIVISOR, 0, 0);
      LED.show();
#endif
      //send samples and calculation result to terminal program through UART
      Serial.print(aun_ir_buffer[i], DEC);
      Serial.print(F(", HR="));
      Serial.print(n_heart_rate, DEC);
      Serial.print(F(", HRvalid="));
      Serial.print(ch_hr_valid, DEC);
      Serial.print(F(", SPO2="));
      Serial.print(n_spo2, DEC);
      Serial.print(F(", SPO2Valid="));
      Serial.println(ch_spo2_valid, DEC);
I have attached the SOftI2CMaster.h code too as well which I think there is a problem with.
Here is the error messages:
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: “Arduino/Genuino Uno”
In file included from Arduino\libraries\RD117_ARDUINO_V01_00\Design Files\RD117_ARDUINO\RD117_ARDUINO.ino:78:0:
sketch\algorithm.h:71:0: warning: “min” redefined
#define min(x,y) ((x) < (y) ? (x) : (y))
In file included from Arduino\libraries\RD117_ARDUINO_V01_00\Design Files\RD117_ARDUINO\RD117_ARDUINO.ino:77:0:
ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/Arduino.h:92:0: note: this is the location of the previous definition
#define min(a,b) ((a)<(b)?(a):(b))
AppData\Local\Temp\ccR6MX8j.ltrans0.ltrans.o: In function `i2c_rep_start(unsigned char) [clone .constprop.12]’:
sketch/SoftI2CMaster.h:334: undefined reference to `ass_i2c_delay_half’
sketch/SoftI2CMaster.h:334: undefined reference to `ass_i2c_wait_scl_high’
AppData\Local\Temp\ccR6MX8j.ltrans0.ltrans.o: In function `i2c_start(unsigned char) [clone .constprop.11]’:
sketch/SoftI2CMaster.h:309: undefined reference to `ass_i2c_wait_scl_high’
sketch/SoftI2CMaster.h:309: undefined reference to `ass_i2c_delay_half’
AppData\Local\Temp\ccR6MX8j.ltrans0.ltrans.o: In function `i2c_read’:
sketch/SoftI2CMaster.h:528: undefined reference to `ass_i2c_delay_half’
sketch/SoftI2CMaster.h:528: undefined reference to `ass_i2c_wait_scl_high’
AppData\Local\Temp\ccR6MX8j.ltrans0.ltrans.o: In function `i2c_write’:
sketch/SoftI2CMaster.h:458: undefined reference to `ass_i2c_delay_half’
sketch/SoftI2CMaster.h:458: undefined reference to `ass_i2c_wait_scl_high’
AppData\Local\Temp\ccR6MX8j.ltrans0.ltrans.o: In function `ass_i2c_stop’:
sketch/SoftI2CMaster.h:382: undefined reference to `ass_i2c_delay_half’
sketch/SoftI2CMaster.h:382: undefined reference to `ass_i2c_wait_scl_high’
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
“Show verbose output during compilation”
option enabled in File → Preferences.
Any help would be much appreciated!
SoftI2CMaster.h Problem.pdf (294 KB)
You start by posting text files AS TEXT FILES, not as stupid pdf files.
You have a file called algorithm.h that contains a duplicate definition for the macro min. Remove that definition of min from that file.
You appear to not have a file called SoftI2CMaster.cpp, where the functions defined in SoftI2CMaster.h are implemented.
Thanks very much for your help. I have reattached the file as .txt
SoftI2CMaster.h Problem.txt (17.4 KB)
Why did you put the file SoftI2CMaster.h in your sketch?
pert:
When I downloaded the zip files from Maxim for the project and then clicked into the .ino file, it automatically created numerous tabs in the sketch (one of which was the SoftI2CMaster.h)
Please provide a link to the page where you downloaded this from. Please use the chain links icon on the toolbar to make the link clickable.
