So my project is using arduino with analog flex sensors (resistors) to turn those into MIDI notes to work in Ableton.
I am using maxuino, I have the serial data coming in. That works. I know I need to use a map function to convert the serial data to MIDI data. There does not seem to be a lot of good documentation for Maxuino once you set it up. I was trying to use Maxuino cause I was hoping it would be easier to set up and change notes for musical functions.
What is my next step?
P.S. I actually started with Arduino IDE and got it working in ableton, but figured there would be easier to use Max for music stuff.
Thanks any help
