maxValue problem, Solved quickly
Hi This is AC voltmeter which is using maxValue - minValue for calculating amplitude of AC signal, I want to add on LCD maxValue to be displayed,.
This is whot I did ( marked by +++++++++++ ) but M=0.00 all the time.
How to fix it ?
  Measuring AC Current Using ACS712
  www.circuits4you.com
#include <LiquidCrystal.h>
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
const int sensorIn = PA7;
int mVperAmp = 185; // use 100 for 20A Module and 66 for 30A Module
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
double maxValue = 0;
  lcd.begin(16, 2);
  Voltage = getVPP();
  VRMS = (Voltage / 2.0) * 0.707; //root 2 is 0.707
  AmpsRMS = (VRMS * 1000) / mVperAmp;
  Serial.print(AmpsRMS);
  Serial.println(" Amps RMS");
  lcd.setCursor(0, 1);
  lcd.print("U=");
  lcd.print(VRMS);
  lcd.setCursor(0, 0);
  lcd.print("M=");
  lcd.print(maxValue);
float getVPP()
  float result;
  int readValue;             //value read from the sensor
  int maxValue = 0;          // store max value here
  //int minValue = 1024;          // store min value here
  int minValue = 4095.0;
  uint32_t start_time = millis();
  while ((millis() - start_time) < 1000) //sample for 1 Sec
    readValue = analogRead(sensorIn);
    // see if you have a new maxValue
    if (readValue > maxValue)
      /*record the maximum sensor value*/
      maxValue = readValue;
    if (readValue < minValue)
      /*record the minimum sensor value*/
      minValue = readValue;
  // Subtract min from max
  //result = ((maxValue - minValue) * 5.0)/1024.0;
  result = ((maxValue - minValue) * 5.0) / 4095.0;
  return result;
You have two different variables called maxValue, one with global scope, and one with local scope - it is visible only in getVPP
Lose the "float" in front of the second one.
float getVPP()
   result;
This way ?
Doesn't make a sens.
Sorry. "int" in front of maxValue.
Or change the global double into an int.
Thanks
it is working.
