Continuing the discussion from Arduino 2.0.3 stuck on loading screen:
may I know what is the problem here
PS C:\Program Files\Arduino IDE> ".\\Arduino IDE"
.\\Arduino IDE
.\\Arduino IDE
PS C:\Program Files\Arduino IDE> & ".\\Arduino IDE"
Arduino IDE 2.1.1
Starting backend process. PID: 15044
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/USER/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-10-06T06:10:50.260Z root INFO Backend Object.initialize: 9.1 ms [Finished 3.441 s after backend start]
2023-10-06T06:10:50.260Z root INFO Backend Object.configure: 8.3 ms [Finished 3.442 s after backend start]
2023-10-06T06:10:50.260Z root INFO Backend MessagingContribution.onStart: 3.4 ms [Finished 3.442 s after backend start]
2023-10-06T06:10:50.262Z root INFO Backend OSBackendApplicationContribution.configure: 1.0 ms [Finished 3.538 s after backend start]
2023-10-06T06:10:50.264Z root INFO Backend DefaultWorkspaceServer.onStart: 1.0 ms [Finished 3.538 s after backend start]2023-10-06T06:10:50.268Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.3 ms [Finished 3.538 s after backend start]
2023-10-06T06:10:50.270Z root WARN Backend PluginLocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 96.3 ms [Finished 3.539 s after backend start]
2023-10-06T06:10:50.271Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.6 ms [Finished 3.539 s after backend start]
2023-10-06T06:10:50.273Z root INFO Backend ElectronTokenBackendContribution.configure: 1.7 ms [Finished 3.541 s after backend start]
2023-10-06T06:10:50.275Z config INFO >>> Initializing CLI configuration...
2023-10-06T06:10:50.276Z root INFO Backend PluginDeployerContribution.initialize: 1.0 ms [Finished 3.541 s after backend start]
2023-10-06T06:10:50.277Z root INFO Backend ConfigServiceImpl.onStart: 2.6 ms [Finished 3.544 s after backend start]
2023-10-06T06:10:50.278Z config INFO Loading CLI configuration from c:\Users\USER\.arduinoIDE\arduino-cli.yaml...
2023-10-06T06:10:50.279Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 1.6 ms [Finished 3.548 s after backend start]
2023-10-06T06:10:50.280Z root INFO Backend ArduinoDaemonImpl.onStart: 3.6 ms [Finished 3.550 s after backend start]
2023-10-06T06:10:50.280Z root INFO Backend NodeFileUploadService.configure: 6.9 ms [Finished 3.550 s after backend start]
2023-10-06T06:10:50.280Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-10-06T06:10:50.281Z discovery-log INFO start
2023-10-06T06:10:50.281Z discovery-log INFO start new deferred
2023-10-06T06:10:50.281Z root INFO Backend HostedPluginLocalizationService.initialize: 1.6 ms [Finished 3.553 s after backend start]
2023-10-06T06:10:50.282Z root INFO Backend BoardDiscovery.onStart: 3.7 ms [Finished 3.556 s after backend start]
2023-10-06T06:10:50.282Z root INFO Backend FileDownloadEndpoint.configure: 2.7 ms [Finished 3.556 s after backend start]2023-10-06T06:10:50.283Z root INFO Backend AuthenticationServiceImpl.onStart: 0.7 ms [Finished 3.559 s after backend start]
2023-10-06T06:10:50.284Z root INFO Backend PluginApiContribution.configure: 1.1 ms [Finished 3.560 s after backend start]
2023-10-06T06:10:50.287Z root INFO Backend HostedPluginReader.configure: 1.2 ms [Finished 3.562 s after backend start]
2023-10-06T06:10:50.287Z root INFO Backend HostedPluginReader.configure: 0.2 ms [Finished 3.563 s after backend start]
2023-10-06T06:10:50.288Z root INFO Backend PlotterBackendContribution.configure: 3.0 ms [Finished 3.567 s after backend start]
2023-10-06T06:10:50.297Z root INFO Theia app listening on http://localhost:62053.
2023-10-06T06:10:50.299Z root INFO Finished starting backend application: 16.4 ms [Finished 3.577 s after backend start]2023-10-06T06:10:50.303Z root WARN The local plugin referenced by local-dir:/c%3A/Users/USER/.arduinoIDE/plugins does not exist.
2023-10-06T06:10:50.304Z root WARN The local plugin referenced by local-dir:/c%3A/Users/USER/.arduinoIDE/extensions does not exist.
2023-10-06T06:10:50.304Z root WARN The local plugin referenced by local-dir:C:\Users\USER\.arduinoIDE\plugins does not exist.
2023-10-06T06:10:50.376Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-10-06T06:10:50.376Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-10-06T06:10:50.377Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-10-06T06:10:50.377Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-10-06T06:10:50.377Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-10-06T06:10:50.377Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-10-06T06:10:50.378Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-10-06T06:10:50.378Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-10-06T06:10:50.378Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-10-06T06:10:50.379Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-10-06T06:10:50.379Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-10-06T06:10:50.379Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-10-06T06:10:50.379Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-10-06T06:10:50.380Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-10-06T06:10:50.380Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-10-06T06:10:50.380Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-10-06T06:10:50.381Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-10-06T06:10:50.381Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-10-06T06:10:50.381Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-10-06T06:10:50.382Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-10-06T06:10:50.382Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-10-06T06:10:50.383Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-10-06T06:10:50.383Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-10-06T06:10:50.384Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-10-06T06:10:50.384Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-10-06T06:10:50.384Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-10-06T06:10:50.385Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-10-06T06:10:50.385Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-10-06T06:10:50.386Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-10-06T06:10:50.386Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-10-06T06:10:50.386Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-10-06T06:10:50.387Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-10-06T06:10:50.387Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-10-06T06:10:50.415Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\USER\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\USER\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\USER\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-10-06T06:10:50.415Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-10-06T06:10:50.416Z config INFO Loaded the CLI configuration.
2023-10-06T06:10:50.422Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/USER/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/USER/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-10-06T06:10:50.423Z config INFO Validating the CLI configuration...
2023-10-06T06:10:50.423Z config INFO The CLI config is valid.
2023-10-06T06:10:50.424Z config INFO <<< Initialized the CLI configuration.
2023-10-06T06:10:50.448Z root INFO Resolve plugins list: 169.9 ms [Finished 3.727 s after backend start]
2023-10-06T06:10:50.459Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 10.7 ms [Finished 3.738 s after backend start]
2023-10-06T06:10:50.466Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 6.7ms [Finished 3.745 s after backend start]
2023-10-06T06:10:50.486Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 20.0 ms [Finished 3.765 s after backend start]
2023-10-06T06:10:50.490Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 4.7 ms [Finished 3.770 s after backend start]
2023-10-06T06:10:50.492Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 1.5 ms [Finished 3.772 s after backend start]
2023-10-06T06:10:50.734Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 242.1 ms [Finished 4.014 s after backend start]
2023-10-06T06:10:50.772Z daemon INFO INFO[0000] Using config file: c:\Users\USER\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.32.3
INFO[0000] Executing `arduino-cli daemon`
Daemon is now listening on 127.0.0.1:62054
{"IP":"127.0.0.1","Port":"62054"}
2023-10-06T06:10:50.773Z daemon INFO Daemon is running.
2023-10-06T06:10:51.047Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 313.3 ms [Finished 4.327 s after backend start]
2023-10-06T06:10:51.341Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 293.3 ms [Finished 4.620 s after backend start]
2023-10-06T06:10:51.342Z daemon INFO INFO[0000] Loading hardware from: C:\Users\USER\AppData\Local\Arduino15\packages
INFO[0000] Loading package arduino from: C:\Users\USER\AppData\Local\Arduino15\packages\arduino\hardware
INFO[0000] Checking signature error="opening signature file: open C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The systemcannot find the file specified." index="C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
INFO[0000] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform platform="arduino:avr@1.8.6"
INFO[0000] Checking existence of 'tools' path: C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loading tools from dir: C:\Users\USER\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loading package builtin from: C:\Users\USER\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\USER\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\USER\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool tool="builtin:dfu-discovery@0.1.2"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.9"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.4.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.13.0"
INFO[0000] Checking signature index="C:\\Users\\USER\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\USER\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Adding libraries dir dir="C:\\Users\\USER\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0000] Loading libraries index file index="C:\\Users\\USER\\AppData\\Local\\Arduino15\\library_index.json"
2023-10-06T06:10:51.552Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 211.2 ms [Finished 4.832 s after backend start]
2023-10-06T06:10:51.553Z daemon INFO INFO[0000] Adding libraries dir dir="C:\\Users\\USER\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir dir="C:\\Users\\USER\\Documents\\Arduino\\libraries" location=user
2023-10-06T06:10:51.747Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 194.7 ms [Finished 5.027 s after backend start]
2023-10-06T06:10:51.883Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 135.5 ms [Finished 5.162 s after backend start]
2023-10-06T06:10:51.891Z discovery-log INFO start request start watch
2023-10-06T06:10:51.893Z discovery-log INFO start requested start watch
2023-10-06T06:10:51.893Z discovery-log INFO start resolved watching
2023-10-06T06:10:52.072Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 188.8 ms [Finished 5.351 s after backend start]
2023-10-06T06:10:52.073Z daemon INFO INFO[0001] starting discovery builtin:serial-discovery process
INFO[0001] starting discovery builtin:mdns-discovery process
2023-10-06T06:10:52.090Z daemon INFO INFO[0001] started discovery builtin:serial-discovery process
INFO[0001] sending command HELLO 1 "arduino-cli 0.32.3" to discovery builtin:serial-discovery
INFO[0001] started discovery builtin:mdns-discovery process
INFO[0001] sending command HELLO 1 "arduino-cli 0.32.3" to discovery builtin:mdns-discovery
2023-10-06T06:10:52.289Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 217.5 ms [Finished 5.569 s after backend start]
2023-10-06T06:10:52.290Z daemon INFO INFO[0001] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
INFO[0001] sending command START_SYNC to discovery builtin:mdns-discovery
INFO[0001] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
INFO[0001] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
INFO[0001] sending command START_SYNC to discovery builtin:serial-discovery
INFO[0001] from discovery builtin:serial-discovery received message type: start_sync, message: OK
INFO[0001] from discovery builtin:serial-discovery received message type: add, port: COM4
2023-10-06T06:10:52.295Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-10-06T06:10:52.297Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2023-10-06T06:10:52.297Z discovery-log WARN Port 'COM4 Serial Port' was already available. Known boards before override: []
2023-10-06T06:10:52.475Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 185.2 ms [Finished 5.754 s after backend start]
2023-10-06T06:10:52.556Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 81.9 ms [Finished 5.836 s after backend start]
2023-10-06T06:10:52.737Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 180.0 ms [Finished 6.016 s after backend start]
2023-10-06T06:10:52.929Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 192.6 ms [Finished 6.209 s after backend start]
2023-10-06T06:10:53.130Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 200.6 ms [Finished 6.409 s after backend start]
2023-10-06T06:10:53.314Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 183.9 ms [Finished 6.593 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
2023-10-06T06:10:53.445Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 130.4 ms [Finished 6.724 s after backend start]
Opening channel for service path '/services/ide-updater'.
2023-10-06T06:10:53.663Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 218.4 ms [Finished 6.943 s after backend start]
2023-10-06T06:10:53.664Z root INFO Deploy plugins list: 169.9 ms [Finished 6.943 s after backend start]
2023-10-06T06:10:54.049Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 343.5 ms [Finished 3.385 s after frontend start]
2023-10-06T06:10:54.352Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 156.6 ms [Finished 3.789 s after frontend start]
2023-10-06T06:10:54.460Z root INFO Start frontend contributions: 978.1 ms [Finished 3.801 s after frontend start]
2023-10-06T06:10:54.461Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-10-06T06:10:54.544Z root INFO [71ee97d7-3ee2-4c1a-a0f3-a4420cb74edf] Waiting for backend deployment: 186.5 ms [Finished 3.979 s after frontend start]
2023-10-06T06:10:55.311Z root INFO [hosted-plugin: 6752] PLUGIN_HOST(6752) starting instance
2023-10-06T06:10:56.279Z root INFO [71ee97d7-3ee2-4c1a-a0f3-a4420cb74edf] Sync of 21 plugins: 1739.5 ms [Finished 5.719 s after frontend start]
> 6.938:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
