Hi all,
I'm using the MB1040 Ultrasonic Sensor for a object detection project but it keeps returning measurements that aren't even close to realistic. For example I put it 1 foot away from a solid wooden plank and it read 250 inches. Does anyone know how to fix the readings that are being returned to me? I attached my code below. Thank you.
This code reads the Analog Voltage output from the
LV-MaxSonar sensors
If you wish for code with averaging, please see
playground.arduino.cc/Main/MaxSonar
Please note that we do not recommend using averaging with our sensors.
Mode and Median filters are recommended.
const int anPin1 = A0;
long distance1;
Serial.begin(9600); // sets the serial port to 9600
void read_sensors(){
Scale factor is (Vcc/512) per inch. A 5V supply yields ~9.8mV/in
Arduino analog pin goes from 0 to 1024, so the value has to be divided by 2 to get the actual inches
distance1 = analogRead(anPin1)/2;
void print_all(){
Serial.print("S1");
Serial.print(" ");
Serial.print(distance1);
Serial.print("inches");
read_sensors();
print_all();
There look to be 15 different versions of that device. which one do you have?
most things in tech and since determine things base in meters or cm, try using a ruler to determine what its reading ot use a different sensor to see if the original sensor is the problem since the code only seems to show what the sensor is reading. also try using the digital pin instead of analog like this guy
https://create.arduino.cc/projecthub/knackminds/how-to-measure-distance-using-ultrasonic-sensor-hc-sr04-a-b9f7f8
the top wiring diagram is the one i'm using
I have the MaxBotix MB1040 Ultrasonic Sensor
We know that, you mentioned it in your first post. There is an "EZx" code that describes the pattern, and a coloured dot on it to tell which one:
https://www.pololu.com/product/794
Also please show us photos of your actual wiring, not a link to a suggested wiring.
Hi all,
I'm using the MB1040 Ultrasonic Sensor for a object detection project but it keeps returning measurements that aren't even close to realistic. Does anyone know how I can fix this issue? I attached my code below. Thank you.
/* CODE BELOW */
LV-MaxSonar sensors
long distance1;
void print_all(){
Serial.print("S1");
Serial.print(" ");
read_sensors();
print_all();
Please re-post your code inline in a message, in code tags as explained in the forum guidelines. The forum, "programming questions" where you should have posted this...
@david_v10, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project
See About the Installation & Troubleshooting category.
Please edit your post, select all code and click the </> button to apply so-called code tags and next save your post. It makes it easier to read, easier to copy and prevents the forum software from incorrect interpretation of the code.
The value from Analog pin may contain noise, or noise may come from the sensor itself. It is better to filter noise. See how to filter noise from sensor
... but only after you have determined that the noise is "normal", i.e. not coming from some goofy mistake that you made.
Double posting is not allowed on this forum:
https://forum.arduino.cc/t/mb1040-ultrasonic-sensor-returning-unrealistic-distances/959255
And, amazingly, you failed to use code tags here even though you were advised about it in the other thread and corrected it!
TOPIC MERGED.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
