MB85RC256V I2C address
Hello folks,
just ran the I2C scanner on a MB85RC256V chip and found the 0x50 to 0x57 (depending on the A0 to A2 setting). But I also found a 0x7C address when adding the chip to the bus.
What is that address for?
Which Arduino are you using?
Which FRAM module are you using or is it a bare chip?
I'm using a UNO an the FRAM is a "I2C FRAM breaktout" (small PCB). The chip is a MB85RC256V.
Strange. Do you see the additional device at 0x7C regardless of the address of the FRAM?
Do you get the same results using a different i2c scanner?
No, when disconnecting the FRAM, the 0x7C disappeared.
Different i2c scanner? Hmm... thought there was only one.
I think there are several out there that pretty much do the same thing. There is one that might be useful. Have a look at this thread as this scanner runs at different clock speeds.
Thanks. I'll try that one.
