MCP 4802 for Motor Application
I am using MCP 4802 DAC IC for motor application (4 motors). I want to control motor individually. Since DAC IC 4802 has dual channel i want to control individual channels. I referred to the datasheet of MCP 4802 at the register level commands. But I am not sure how to use it. What specific command should be used for controlling particular channel. I am using 8 bit DAC.
Try the library. It comes with examples
What kind of motors, and how is a DAC involved in controlling them?
Please post a schematic of your proposed circuit.
a7
Motor which will be used is a bldc motor. Motor is controlled using TPS (Throttle Position Sensor). TPS value are first taken by microcontroller and then using DAC IC's they are given to the motor. I dont have the schematic as of now.
