Hello - I am planning on using a mcp1700-5002 to regulate voltage. I have it hooked to 6v from 4 aaa batteries. even with open power out and ground leads, the chip is too hot to touch. Is this normal. I thought these were super low power draw.
No, that's not normal although the maximum input voltage is 6V so use a multimeter and make sure that your input voltage is actually below that.
Can you post a schematic of how you've connected it? What capacitors are you using on the input and output?
Thank you for the quick response. I have no capacitors hooked to it. I am going directly from battery positive to Vin and battery negative to ground. I am getting 6.2 volts. I forgot about the 6 volt limit. I could not find the chip with a higher volt in rating. I could use a 7805. I am only going to power the unit for a minute or two a day. Or am I better with 3 batteries and a boosting regulator to get 5 volts? I am going to be sending and sms when it is on and I think there can be a very very short moment at 2 amps, people have not been able to even see the jump on a meter.
Check the datasheet- voltage regulators need capacitors on the input and out to function properly.
You should easily be able to find a voltage regulator with a higher maximum input. What output voltage do you need?
The MCP1700 is only rated for 250mA so if you're expecting to draw higher currents you need something more powerful.
I am using an Arduino mini pro 5v. It will have hall sensors going into it along with an a6-thinker board. I could go with a lower volt mini pro if needed.
As far as power, it need to be a battery. I can go with a bank of 3-aaa, 4-aaa, 3.7v lipo or 7.4c lipo. I have them all right now. I need to send one text per day.
aiannar974:
First off, appreciate that for around half their battery life, 1.5V batteries (Alkaline ?) will actually be 1.2V so feeding 4.8V into a 5V regulator is not going to give you 5V out, you might as well not bother with the regulator.
Assume 1.2V for Alaklines and plan accordingly. 5 x aaa would be a far better choice.
Second Vin max for the MCP1700 is 6V, new Alkalines are likely to be 1.55V, so yout input voltage is likely 6.2V.
The MCP1702 has a max Vin of 13.2V, so good to go for 5 x aaa.
