mcp23016 - ZX-RelayY16 [SOLVED]
I need help :slight_smile:
I am using a mcp23016 Multiplexer in a ZX-RelayY16 board and I need to active the different relay, one by one.
I am using this code and it nearly works. However it does this sequence:
1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0
1 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0
1 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0
1 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0
1 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0
1 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0
1 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0
1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1
I can’t understand how mcp23016 works. Anyone can help me :slight_smile:
Pierre
#include <Wire.h> // specify use of Wire.h library.
/* RELAY */
#define MCP23016_I2C_ADDRESS 0x20
#define GP0    0x00                    // register addresses
#define GP1     0X01
#define OLAT0   0x02
#define OLAT1   0x03
#define IPOL0   0x04
#define IPOL1   0x05
#define IODIR0  0x06
#define IODIR1  0x07
#define INTCAP0 0x08
#define INTCAP1 0x09
#define IOCON0  0x0A
#define IOCON1  0x0B
int jj = 0;
  Wire.begin();
  Wire.beginTransmission(MCP23016_I2C_ADDRESS);  // setup out direction registers
  Wire.endTransmission();
    Wire.beginTransmission(0x20);  // set mcp23016 for all output
    Serial.println(jj);
    if (jj<8) {
            Wire.write(GP1);
            Wire.write(GP0);
     }else{
            Wire.write(GP0);
            Wire.write(GP1);
      if (jj==7) Wire.write(128);
      if (jj==6) Wire.write(64);
      if (jj==5) Wire.write(32);
      if (jj==4) Wire.write(16);
      if (jj==3) Wire.write(8);
      if (jj==2) Wire.write(4);
      if (jj==1) Wire.write(2);
      if (jj==0) Wire.write(1);
      if (jj==15) Wire.write(128);
      if (jj==14) Wire.write(64);
      if (jj==13) Wire.write(32);
      if (jj==12) Wire.write(16);
      if (jj==11) Wire.write(8);
      if (jj==10) Wire.write(4);
      if (jj==9) Wire.write(2);
      if (jj==8)  Wire.write(1);
    if (jj > 16) jj = -1;
    jj++;
    delay(1000); // }
} // end loop
Untested but it should be close:-
 byte bitToSet = 0;
    Serial.println(jj);
    if (jj<8) {
            Wire.write(GP0);
            bitToSet = 1 << jj;
     }else{
            Wire.write(GP1);
            bitToSet = 1 << (jj-8);
      Wire.write(bitToSet);
    if (jj > 14) jj = -1;
    jj++;
    delay(1000); // }
} // end loop
Up !
Thanks Grumpy, but still doesn't work... it's close yes but it does something like:
1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1
0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1
0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 1
0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 1 0 1 0 0 0 0 0 0 0
0 0 0 0 0 0 0 1 0 0 1 0 0 0 0 0 0
:astonished:
I found ! It’s not well optimmised, but it works :slight_smile:
/* RELAY */
#define GP1     0X01
#define OLAT0   0x02
#define OLAT1   0x03
#define IPOL0   0x04
#define IPOL1   0x05
#define IODIR0  0x06
#define IODIR1  0x07
#define IOCON0  0x0A
#define IOCON1  0x0B
int jj = 0;
  Wire.begin();
   jj++;
    Wire.write(IODIR0);  // pointer
    Wire.write(GP0);  // DDR Port0 all output
    Wire.write(GP1);  // DDR Port1 all input
        Wire.write(GP0);
        Wire.write(0);
        Wire.write(GP0);
        Wire.write(1);
        Wire.write(GP0);
        Wire.write(0);
        Wire.write(GP0);
        Wire.write(2);
        Wire.write(GP0);
        Wire.write(0);
        Wire.write(GP0);
        Wire.write(128);
        Wire.write(GP0);
        Wire.write(0);
        Wire.write(GP1);  // DDR Port0 all output
        Wire.write(GP0);  // DDR Port1 all input
        Wire.write(GP1);
        Wire.write(1);
        Wire.write(GP1);
        Wire.write(2);
        Wire.write(GP1);
        Wire.write(128);
        Wire.write(GP1);
        Wire.write(0);
} // end loop
pierromond:
Thanks Grumpy, but still doesn’t work… it’s close yes but it does something like:
:astonished:
yes looks like I forgot to clear the register when swapping over to the other one, problem is I was trying to keep it close to your code.
You can say that again.
