MCP23017 addressing certain pin
Hello, the code triggers all ports on and off. However, I need to address a specific pin (e.g. A0) and don't know how to implent it.
Appreciate any help as Adafruit library didn't work for me with the 2560.
#include <Wire.h>
const byte  mcp_address=0x20;      // I2C Address of MCP23017 Chip
const byte  GPIOA=0x12;            // Register Address of Port A
const byte  GPIOB=0x13;            // Register Address of Port B
  Wire.begin();              // join i2c bus (address optional for master)
  Wire.beginTransmission(mcp_address);
  Wire.write((byte)0x00); // IODIRA register
  Wire.write((byte)0x00); // set all of bank A to outputs
  Wire.write((byte)0x00); // set all of bank B to outputs
  Wire.endTransmission();
  Wire.write(GPIOA);      // address bank B
  Wire.write((byte)0xFF);  // value to send - all HIGH ([u]I need only one pin and not all[/u])
  Wire.write((byte)0x00);  // value to send - all LOW
  Wire.write(GPIOB);      // address bank B
vaxman:
Why not?
That would be the first thing to determine.
If I remember you simply have to a read mask write operation but I am not positive on that. Try this link, it has lots of examples: MCP23017: Have you run out of I/O? This chip is the answer!
My bad: I forgot to declare pins as output and therefore, I blamed the library.
Thank you all.
