MCP23017 and interrupts and Adafruit MCP23017 library
nickgammon:
I have some test code below which tests interrupts on the MCP23017. I just checked and it works fine:
/// Author: Nick Gammon
// Date: 19 February 2011
// Demonstration of an interrupt service routine connected to the MCP23017
#include <Wire.h>
// MCP23017 registers (everything except direction defaults to 0)
#define IODIRA  0x00  // IO direction  (0 = output, 1 = input (Default))
#define IODIRB  0x01
#define IOPOLA  0x02  // IO polarity  (0 = normal, 1 = inverse)
#define IOPOLB  0x03
#define GPINTENA 0x04  // Interrupt on change (0 = disable, 1 = enable)
#define GPINTENB 0x05
#define DEFVALA  0x06  // Default comparison for interrupt on change (interrupts on opposite)
#define DEFVALB  0x07
#define INTCONA  0x08  // Interrupt control (0 = interrupt on change from previous, 1 = interrupt on change from DEFVAL)
#define INTCONB  0x09
#define IOCON    0x0A  // IO Configuration: bank/mirror/seqop/disslw/haen/odr/intpol/notimp
//#define IOCON 0x0B  // same as 0x0A
#define GPPUA    0x0C  // Pull-up resistor (0 = disabled, 1 = enabled)
#define GPPUB    0x0D
#define INFTFA  0x0E  // Interrupt flag (read only) : (0 = no interrupt, 1 = pin caused interrupt)
#define INFTFB  0x0F
#define INTCAPA  0x10  // Interrupt capture (read only) : value of GPIO at time of last interrupt
#define INTCAPB  0x11
#define GPIOA    0x12  // Port value. Write to change, read to obtain value
#define GPIOB    0x13
#define OLLATA  0x14  // Output latch. Write to latch output.
#define OLLATB  0x15
#define port 0x20  // MCP23017 is on I2C port 0x20
#define ISR_INDICATOR 12  // pin 12
#define ONBOARD_LED 13    // pin 13
volatile bool keyPressed;
// set register “reg” on expander to “data”
// for example, IO direction
void expanderWriteBoth (const byte reg, const byte data )
  Wire.beginTransmission (port);
  Wire.write (reg);
  Wire.write (data);  // port A
  Wire.write (data);  // port B
  Wire.endTransmission ();
} // end of expanderWrite
// read a byte from the expander
unsigned int expanderRead (const byte reg)
  Wire.write (reg);
  Wire.requestFrom (port, 1);
  return Wire.read();
} // end of expanderRead
// interrupt service routine, called when pin D2 goes from 1 to 0
void keypress ()
  digitalWrite (ISR_INDICATOR, HIGH);  // debugging
  keyPressed = true;  // set flag so main loop knows
}  // end of keypress
void setup ()
  pinMode (ISR_INDICATOR, OUTPUT);  // for testing (ISR indicator)
  pinMode (ONBOARD_LED, OUTPUT);  // for onboard LED
Wire.begin ();
  Serial.begin (115200);
  Serial.println (“Starting …”);
// expander configuration register
  expanderWriteBoth (IOCON, 0b01100000); // mirror interrupts, disable sequential mode
// enable pull-up on switches
  expanderWriteBoth (GPPUA, 0xFF);  // pull-up resistor for switch - both ports
// invert polarity
  expanderWriteBoth (IOPOLA, 0xFF);  // invert polarity of signal - both ports
  // enable all interrupts
  expanderWriteBoth (GPINTENA, 0xFF); // enable interrupts - both ports
  // no interrupt yet
  keyPressed = false;
// read from interrupt capture ports to clear them
  expanderRead (INTCAPA);
  expanderRead (INTCAPB);
  // pin 19 of MCP23017 is plugged into D2 of the Arduino which is interrupt 0
  attachInterrupt(0, keypress, FALLING);
}  // end of setup
// time we turned LED on
unsigned long time = 0;
// called from main loop when we know we had an interrupt
void handleKeypress ()
  unsigned int keyValue = 0;
  delay (100);  // de-bounce before we re-enable interrupts
  keyPressed = false;  // ready for next time through the interrupt service routine
  digitalWrite (ISR_INDICATOR, LOW);  // debugging
  // Read port values, as required. Note that this re-arms the interrupts.
  if (expanderRead (INFTFA))
    keyValue |= expanderRead (INTCAPA) << 8;    // read value at time of interrupt
  if (expanderRead (INFTFB))
    keyValue |= expanderRead (INTCAPB);        // port B is in low-order byte
  Serial.println (“Button states”);
  Serial.println (“0                  1”);
  Serial.println (“0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5”);
  // display which buttons were down at the time of the interrupt
  for (byte button = 0; button < 16; button++)
    // this key down?
    if (keyValue & (1 << button))
      Serial.print ("1 ");
      Serial.print ("0 ");
    } // end of for each button
Serial.println ();
  // if a switch is now pressed, turn LED on  (key down event)
  if (keyValue)
    time = millis ();  // remember when
    digitalWrite (ONBOARD_LED, HIGH);  // on-board LED
    }  // end if
}  // end of handleKeypress
void loop ()
  // was there an interrupt?
  if (keyPressed)
    handleKeypress ();
// turn LED off after 500 ms
if (millis () > (time + 500) && time != 0)
    digitalWrite (ONBOARD_LED, LOW);
    time = 0;
  }  // end if time up
}  // end of loop
Wiring:
![](http://www.gammon.com.au/images/Arduino/MCP23017_wiring.png)
Put an LED on pin 12 (to see interrupts). Ground any of the data pins and the ISR LED should flash. Plus in the serial monitor you will see the pin states.
I just found this post by Nick Gammon: configuration for 1 MCP23017. How would this have to be written if more than one MCP23017 are connected to the same I2C bus?
Post split from a 4 year old topic to create this new one
UKHeliBob:
Thank you UKHeliBob
For reference the old topic is RE MCP23017 and interrupts and Adafruit MCP23017 library - Programming Questions - Arduino Forum
