MCP23017 blink without delay
Hi everyone,
I am working on blinking one LED at a time for 16 LEDs on an MCP23017 16-bit io expander. I am using an Arduino Mega. I have a problem, the code below using blink without delay could not light a single LED. Please help.
#include "Adafruit_MCP23017.h"
Adafruit_MCP23017 mcp;
int i, state = 0;
unsigned long current_time, previous_time = 0;
  Serial.begin(19200);
  mcp.begin();
  for (i = 0; i < 15; i++)
    mcp.pinMode(i, OUTPUT);
  i = 0;
  //for (i = 0; i < 15; i++)
    current_time = millis();
    if (current_time - previous_time >= 2000)
      previous_time = current_time;
      if (state == 0)
        state = 1;
      if (state == 1)
        state = 0;
      mcp.digitalWrite (i, state);
Hello,
Change to else if (state == 1), or state will always be set to 0.
A better idea is to change the type of state to bool, then you can invert its value by doing state = !state;, so that you don't need the if/else if
Thanks guix, the LED at GPIO 0 is blinking now. Now, working to blink all the 16 LEDs.
int i, state = 0;
  mcp.begin();
  i = 0;
      if (state == 0)
        state = 1;
        state = 0;
Guys, I figured it out. Thanks.
int i, state = 0;
  mcp.begin();
  for (i = 0; i < 16; i++)
  for (i = 0; i<16; i++)
    state = 0;
    do
      if (current_time - previous_time >= 500)
        if (state == 0)
          state = 1;
          state = 0;
          state = 2;
    while (state != 2);
I didn't have to look far.
int i, state = 0;
  Serial.begin(19200);   // why so slow?
  mcp.begin();
  // move this line up
  i = 0;         // the initializer belongs in setup KUDOS for using void loop() to loop!
      if (state == 0)
        state = 1;
        state = 0;
  //  here you need to decide when to increment  i  including 0 to 15 bounds keeping.
why int i starts from 0 to 16, not 0 to 15 for MCP23017?
Where you get 16? I'm already wearing glasses.
I tried to change to for (i = 0; i < 15; i++), the 16th LED will not light up.
should be <= 15 if you want [15] to process.
I didn't correct the comment which is in the original I worked from.
I left this comment below;
It would be an if ( ++i > 15 ) i = 0; kind of line.
