Hi everybody.
I try to use MCP23S17 on my arduino Micro. I use library from playground. I define SS on pin 10 and use standard pins for MISO,MOSI and SCK. My problem is nothing appênds. I connect 8 LED (one for each ppins on ports A) and run this program:
#include <SPI.h>
#include <MCP23S17.h>
#define ON 1
#define OFF 0
MCP chip1(0);
MCP chip2(1);
MCP chip3(2);
MCP chip4(3);
MCP chip5(4);
MCP chip6(5);
MCP chip7(6);
MCP chip8(7);
MCP chip9(8);
while (!Serial);
Serial.println("GO");
Serial.println("SS:" + String(SS));
Serial.println("SCK:" + String(SCK));
Serial.println("MOSI:" + String(MOSI));
Serial.println("MISO:" + String(MISO));
delay(10000);
for (int i = 1;i<=16;i++)
chip1.pinMode(i,OUTPUT);
chip2.pinMode(i,OUTPUT);
chip3.pinMode(i,OUTPUT);
chip4.pinMode(i,OUTPUT);
chip5.pinMode(i,OUTPUT);
chip6.pinMode(i,OUTPUT);
chip7.pinMode(i,OUTPUT);
chip8.pinMode(i,OUTPUT);
chip9.pinMode(i,OUTPUT);
for (int chip =1;chip <= 9;chip++)
switch (chip)
case 1: chip1.digitalWrite(i,ON); delay(100); chip1.digitalWrite(i,OFF); break;
case 2: chip2.digitalWrite(i,ON); delay(100); chip2.digitalWrite(i,OFF); break;
case 3: chip3.digitalWrite(i,ON); delay(100); chip3.digitalWrite(i,OFF); break;
case 4: chip4.digitalWrite(i,ON); delay(100); chip4.digitalWrite(i,OFF); break;
case 5: chip5.digitalWrite(i,ON); delay(100); chip5.digitalWrite(i,OFF); break;
case 6: chip6.digitalWrite(i,ON); delay(100); chip6.digitalWrite(i,OFF); break;
case 7: chip7.digitalWrite(i,ON); delay(100); chip7.digitalWrite(i,OFF); break;
case 8: chip8.digitalWrite(i,ON); delay(100); chip8.digitalWrite(i,OFF); break;
case 9: chip9.digitalWrite(i,ON); delay(100); chip9.digitalWrite(i,OFF); break;
Serial.println("Chip:(" + String(chip) + ") Pin:(" + String(i) + ")");
system
September 10, 2015, 8:50pm
2
Are you really connecting LEDs to pins 0 and 1, AND using those pins for Serial, too? Do you really have an LED on the 8) pin?
Thank for reply
LEDs are connected to pins 1 to 8 of the MCP23S17; Nothing are connected on MIRCO except MCP23S17
system
September 10, 2015, 9:12pm
4
mrobergedr:
Thank for reply
I think a schematic is in order, then.
An array of MCP objects would make that silly inner for loop a lot less messy.
Looping 9 times, and doing something different each time certainly makes the loop ineffective.
My problem is that I don't understand that statement. I can't figure out what you want to append to what.
I just want to know if someone was able to use MCP23S17 with an Arduino MICRO.
See Buttons, I2C, interrupts and port-expanders
@mrobergedr :
Please use code tags.
Read this before posting a programming question
Please edit your post, select the code, and put it between [ code ] ... [ /code ] tags.
You can do that by hitting the "Code" icon above the posting area. It is the first icon, with the symbol: </>
How to use this forum
What pins, exactly?
See https://www.arduino.cc/en/Main/ArduinoBoardMicro
SPI: on the ICSP header. These pins support SPI communication using the SPI library. Note that the SPI pins are not connected to any of the digital I/O pins as they are on the Arduino/Genuino Uno, they are only available on the ICSP connector and on the nearby pins labelled MISO, MOSI and SCK.
Sorry but I don't know how to send schematic
on arduino on MCP23S17
pin 1 left side (MOSI) pin 13 (SI)
pin 2 right side (MISO) pin 14 (SO)
pin 1 right side (SCK) pin 12 (CLK)
pin 15 left side (IO10) pin 11 (CS)
pin 10 to Ground)
pin 9 to VDD
pin 15-16-17 to ground add 0
pin 18 RESET to VDD
pin 21 to 28 to LEDs
This is the new code:
#include <SPI.h>
#define SS (10)
#define ON 1
#define OFF 0
MCP chip1(0);
pinMode(SS, OUTPUT);
pinMode(SCK, OUTPUT);
pinMode(MOSI, OUTPUT);
pinMode(MISO, INPUT);
while (!Serial);
SPI.begin();
Serial.println("Pin:(" + String(i) + ")");
while (!Serial);
There's no Serial.begin().
I made the correction but no led bliking.
#include <SPI.h>
#define ON 1
#define OFF 0
MCP chip1(0);
while (!Serial);
SPI.begin();
You only have one delay there:
That means they will be on most of the time.
How about:
delay(100);
delay(100);
And don't try to cram lots of statements on one line. Code is supposed to be readable.
I hope you have resistors in series with your LEDs. Do you?
on for 100 millisecond, turn off and next led on for 100 millisecond and so on.
Yes I have resistor on LEDs.
If I move the LEDs to the Arduino port 3 to 10 and change the code to:
for (int i = 3;i<=10;i++)
digitalWrite(i,ON);
delay(100);
the LEDs work well so it's not the LEDs who is the problem but the MCP. I just want to be sure that the arduino Micro board can drive a MCP23S17 , because I did not find schematic using it only UNO nano and mega.
Certainly it can. Perhaps take a photo of your setup?
I got it to work with my own code. Here is the wiring:
Here is the code:
// MCP23017 and MCP23S17 demo
// Author: Nick Gammon
// Date: 11 September 2015
#include <Wire.h>
#include <SPI.h>
// MCP23017 registers (everything except direction defaults to 0)
const byte IODIRA = 0x00; // IO direction (0 = output, 1 = input (Default))
const byte IODIRB = 0x01;
const byte IOPOLA = 0x02; // IO polarity (0 = normal, 1 = inverse)
const byte IOPOLB = 0x03;
const byte GPINTENA = 0x04; // Interrupt on change (0 = disable, 1 = enable)
const byte GPINTENB = 0x05;
const byte DEFVALA = 0x06; // Default comparison for interrupt on change (interrupts on opposite)
const byte DEFVALB = 0x07;
const byte INTCONA = 0x08; // Interrupt control (0 = interrupt on change from previous, 1 = interrupt on change from DEFVAL)
const byte INTCONB = 0x09;
const byte IOCON = 0x0A; // IO Configuration: bank/mirror/seqop/disslw/haen/odr/intpol/notimp
const byte GPPUA = 0x0C; // Pull-up resistor (0 = disabled, 1 = enabled)
const byte GPPUB = 0x0D;
const byte INFTFA = 0x0E; // Interrupt flag (read only) : (0 = no interrupt, 1 = pin caused interrupt)
const byte INFTFB = 0x0F;
const byte INTCAPA = 0x10; // Interrupt capture (read only) : value of GPIO at time of last interrupt
const byte INTCAPB = 0x11;
const byte GPIOA = 0x12; // Port value. Write to change, read to obtain value
const byte GPIOB = 0x13;
const byte OLLATA = 0x14; // Output latch. Write to latch output.
const byte OLLATB = 0x15;
const byte DEVICE_ADDRESS = 0x20; // MCP23017 is on I2C port 0x20
const byte ssPin = 10; // slave select pin, if non-zero use SPI
const byte expanderPort = 0x20;
// set register "reg" on expander to "data"
// for example, IO direction
void expanderWrite (const byte reg, const byte data )
startSend ();
doSend (reg);
doSend (data);
endSend ();
} // end of expanderWrite
// prepare for sending to MCP23017
void startSend ()
if (ssPin)
digitalWrite (ssPin, LOW);
SPI.transfer (expanderPort << 1); // note this is write mode
Wire.beginTransmission (expanderPort);
} // end of startSend
// send a byte via SPI or I2C
void doSend (const byte what)
if (ssPin)
SPI.transfer (what);
Wire.write (what);
} // end of doSend
// finish sending to MCP23017
void endSend ()
if (ssPin)
digitalWrite (ssPin, HIGH);
Wire.endTransmission ();
} // end of endSend
void setup ()
if (ssPin) // if we have an SS pin it is SPI mode
SPI.begin ();
pinMode (ssPin, OUTPUT);
Wire.begin (DEVICE_ADDRESS);
// byte mode (not sequential)
expanderWrite (IOCON, 0b00100000);
// all pins as outputs
expanderWrite (IODIRA, 0);
expanderWrite (IODIRB, 0);
} // end of setup
void loop ()
expanderWrite (GPIOA, 0xAA);
delay (100);
expanderWrite (GPIOA, 0);
delay (100);
} // end of loop
As you can see from the photo, half of the LEDs are on (as I sent 0xAA) and I can assure you that they flash.
Note : you must open the serial monitor, or the code hangs waiting for the Serial connection to be established.
Your code sort-of works as well, although the serial prints in loop() slow it right down. Also one of the pins flickers in a rather strange way.
Still, I suggest if neither my code nor your code works, you have a wiring problem.
thank I will try it tomorow
Thank you very much. It's working. I will study your sketch and build my own class for driving stepper motor with MCP23S17
system
September 11, 2015, 3:48pm
19
You realize, I hope, that driving a low voltage, low current LED and driving a high voltage, high current stepper motor are QUITE different tasks.
Yes I have builded a high current driver using TIP122.
I am not a beginner with arduino and electronic. I had just use a library who don't work. But SPI for me are really new.
Thank a lot for your time and patience
