MCP23S17 I/O expander with Arduino SPI library not reading pin values
The following sketch is my failed attempt to read MCP23S17 pin values using the Arduino SPI library.
The setup is four normally open buttons connected to MCP23S17 port B input pins 0-3.
link to picture of hardware
When a button is pressed, Serial.print is supposed to display what button was pressed.
The expected output is:
1           //button 1 pressed
10          //button 2 pressed
100         //button 3 pressed
1000        //button 4 pressed
1111        //all four buttons pressed
In reality the sketch always prints 1 for all pins; no matter what the pin values are:
11111111
11111111
11111111
11111111
sketch:
#include <SPI.h>
const uint8_t ADDR = 0x20;              //MCP23S17 address, all ADDR pins are grounded
const uint8_t OPCODE_WRITE = (ADDR << 1 | 0x00);  //MCP23S17 opcode write has LSB clear
const uint8_t OPCODE_READ  = (ADDR << 1 | 0x01);  //MCP23S17 opcode read  has LSB set
const uint8_t IODIRB = 0x01;            //buttons are on port B
const uint8_t GPIOB  = 0x13;
uint8_t buttonState = 0;                 //bit wise
uint8_t IOERead(const uint8_t REGISTER_ADDR)
    uint8_t data;
    SPI.beginTransaction(SPISettings (SPI_CLOCK_DIV8, MSBFIRST, SPI_MODE0)); //gain control of SPI bus
    digitalWrite(SS, LOW);              //enable Slave Select
      SPI.transfer(OPCODE_READ);        //read command
      SPI.transfer(REGISTER_ADDR);      //register address to read data from
      data = SPI.transfer(0);           //save the data (0 is dummy data to send)
    digitalWrite(SS, HIGH);             //disable Slave Select
    SPI.endTransaction();               //release the SPI bus
    return data;
    pinMode(SS, OUTPUT);                //configure controller's Slave Select pin to output
    SPI.begin();
    //IODIRB register is already configured to input by default
    buttonState = IOERead(GPIOB);
    if (buttonState > 0)                //if a button was pressed
        Serial.println(buttonState, BIN);
        delay(200);
Buttons are active high with external pull-down resistors.
The pin's voltage is normally low.
When a button is pressed, the pin's voltage is pulled high.
I confirmed the pin voltages with a multi-meter.
The controller is Teensy LC (3.3 volts) on Arduino 1.6.7.
Teensy LC pin out: https://www.pjrc.com/teensy/card6a_rev2.png
MCP23S17 datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/20001952C.pdf
SPI library: SPI - Arduino Reference
I have read the datasheet, the Arduino SPI library reference, and some SPI examples.
Please tell me what I am missing.
It's working now. Here is what was missing:
A jumper from the micro-controller MOSI pin to the MCP23S17 SO pin.
So that the read command can travel from micro-controller to MCP23S17.
