MCP23S17 port B problem. I get 11111111 continuously
Hi I made a test breadboard with an Arduino Nano + MCP23S17 IC
I read @wolfv's topic, about the I/O expander problem. And I used his code, but I have a problem.
I put buttons into the port A and B, the A ports works well, but I get 11111111 from B ports continuously.
I used this wire schematic: link
I put 10K resitors between the pins and the buttons!
Can you help me, what is the problem:
// this constant won't change:
#include <SPI.h>              // We use this library, so it must be called here.
#include <Wire.h>
const int  buttonPin = 7;    // the pin that the pushbutton is attached to
const int  buttonPin2 = 6;    // the pin that the pushbutton is attached to
const uint8_t ADDR = 0x20;              //MCP23S17 address, all ADDR pins are grounded
const uint8_t OPCODE_WRITE = (ADDR << 1 | 0x00);  //MCP23S17 opcode write has LSB clear
const uint8_t OPCODE_READ  = (ADDR << 1 | 0x01);  //MCP23S17 opcode read  has LSB set
const uint8_t IODIRA = 0x00;  // I/O direction A
const uint8_t IODIRB = 0x01;            //buttons are on port B
const uint8_t GPIOA = 0x12;  // port A
const uint8_t GPIOB  = 0x13;
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonPushCounter2 = 0;   // counter for the number of button presses
int buttonPushCounter3 = 0;   // counter for the number of button presses
int buttonPushCounter4 = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int buttonState2 = 0;         // current state of the button
uint8_t buttonState3 = 0;                 //bit wise
uint8_t buttonState4 = 0;                 //bit wise
int lastButtonState = 0;     // previous state of the button
int lastButtonState2 = 0;     // previous state of the button
int lastButtonState3 = 0;     // previous state of the button
int lastButtonState4 = 0;     // previous state of the button
uint8_t IOERead(const uint8_t REGISTER_ADDR)
    uint8_t data;
    SPI.beginTransaction(SPISettings (SPI_CLOCK_DIV8, MSBFIRST, SPI_MODE0)); //gain control of SPI bus
    digitalWrite(SS, LOW);              //enable Slave Select
      SPI.transfer(OPCODE_READ);        //read command
      SPI.transfer(REGISTER_ADDR);      //register address to read data from
      data = SPI.transfer(0);           //save the data (0 is dummy data to send)
    digitalWrite(SS, HIGH);             //disable Slave Select
    SPI.endTransaction();               //release the SPI bus
    return data;
  pinMode(buttonPin, INPUT);
  pinMode(buttonPin2, INPUT);
  pinMode(SS, INPUT);                //configure controller's Slave Select pin to output
  digitalWrite(SS, LOW);             //disable Slave Select
  SPI.begin();
    // initialize serial communication:
  // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
  buttonState2 = digitalRead(buttonPin2);
  buttonState3 = IOERead(GPIOB);
  buttonState4 = IOERead(GPIOA);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button
      // wend from off to on:
      buttonPushCounter++;
      Serial.println("BE");
      Serial.print("Első VELOSTAT:  ");
      Serial.println(buttonPushCounter);
      // if the current state is LOW then the button
      // wend from on to off:
      Serial.println("KI");
    // Delay a little bit to avoid bouncing
    delay(50);
  if (buttonState2 != lastButtonState2) {
    if (buttonState2 == HIGH) {
      buttonPushCounter2++;
      Serial.print("Második VELOSTAT:  ");
      Serial.println(buttonPushCounter2);
    delay(50);
    if (buttonState3 > lastButtonState3)                //if a button was pressed
        Serial.print("PIN:  ");
        Serial.println(buttonState3, BIN);
        Serial.print("B");
        buttonPushCounter3++;
        Serial.println(buttonPushCounter3);
        delay(200);
    if (buttonState4 > 0)                //if a button was pressed
        Serial.println(buttonState4, BIN);
        Serial.print("A");
        buttonPushCounter4++;
        Serial.println(buttonPushCounter4);
        delay(200);
    // save the current state as the last state,
  //for next time through the loop
   lastButtonState = buttonState;
   lastButtonState2 = buttonState2;
   lastButtonState3 = buttonState3;
   lastButtonState4 = buttonState4;
I'm not that conversant with SPI but,
It's always a pleasure to see comments describing exactly what the corresponding code is doing...
if you configure the SS pin as an input your SPI interface won't go into master mode, so your sketch won't work.
SS is disabled by driving it HIGH, so once more a comment saying the opposite of the code in front of it.
Pulldown resistors should go from input pin to ground, I believe SCK is pin 13.
