Hi there,
My apologies if this has already been covered, but I seemed to notice a very odd thing when using the MCP23S17 with the Arduino.
Just to let you know, I am using the MCP23S17 library with it, and not plain SPI commands. I will use those next if this doesn't work as planned.
Basically, I was trying to talk to the MCP23S17, and it wasn't working. I have three LEDs wired to pins GPB5,6 and 7, or pins 14,15 and 16 according to the library.
I had the following code:
#include <SPI.h>
#include <MCP23S17.h>
#include <LiquidCrystal.h>
MCP onechip(0);
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
lcd.begin(20, 4);
lcd.print("Hello");
// Initialize SPI to talk to the DAC
SPI.begin();
pinMode(6,OUTPUT);
onechip.pinMode(15,LOW);
digitalWrite(6, LOW);
onechip.digitalWrite(15,HIGH);
digitalWrite(13,HIGH);
onechip.digitalWrite(15,LOW);
digitalWrite(13,LOW);
digitalWrite(6,HIGH);
Originally the code wasn't working, but somehow it started to work, and I started to get my LEDs to blink as I wanted.
However, I noticed that with each new programming exercise, the LEDs started to get dimmer and dimmer. Till the whole system stopped working altogether.
Basically I have three LEDs as outputs and rest are inputs, which are buttons that are pulled up by default and get pulled to zero when pressed. I hadn't gone as far as testing those properly.
I do not have my scope with me right now (joys of working between two sites), but I will definitely probe it with a scope to see what is going on.
Overall, I can think of two obvious problems:
- I killed the MCP23S17 somehow
- The library has some issues and doesn't work the same way every time
I am hoping the solution is a bit more obvious, as if in adjusting my code I have done something silly which I cannot see (too close to the problem).
The final code that I have in my setup is above.
Any help, or anybody with experience on the MCP23S17, your feedback would be appreciated.
