MCP2515 buffer problem?
Hi all,
I'm working on a small dashboard to be connected on motorcycles CAN data bus.
The hardware is based on the Sparkfun shield (MCP2251/MCP2515), but shrunk down to a single SMD concept.
It should work in a passive way, reading the cyclic messages on the bus and writing some values on a 128x64 display.
CAN messages are sent from the motorcycle ECU every 100ms.
I am at the moment only interested on two messages IDs (there are ~50 IDs in the bus).
The initial test code is working correctly when I simulate the bus with only the messages I'm interested on, but when I connect it to the real bus, data is updated randomly with delay varying from 20 seconds to 10 minutes.
It looks like a buffer congestion, I tried applying filters but the problem is still there...
Can you maybe give me some suggestions on how to solve the problem??
Here's part of the code:
#include <SPI.h>
#include "mcp_can.h"   // sparkfun library
// include the library header
// no font headers have to be included
#include <openGLCD.h>
#define SPI_CS_PIN 10
unsigned int canId = 0x00;
unsigned char len = 0;
unsigned char buf[8];
unsigned char temp;
int data1 = 0;  // initializing values
int voltage = 0;
float voltagemin = 0;
float voltagemax = 0;
int temperaturemin = 0;
int temperaturemax = 0;
int pof = 0;
MCP_CAN CAN(SPI_CS_PIN);                                    // Set CS pin
  // Initialize the GLCD
  GLCD.Init();
  START_INIT:
    if(CAN_OK == CAN.begin(CAN_500KBPS))                   // init can bus : baudrate = 500k
          Serial.println("CAN BUS init ok!");
          Serial.println("CAN BUS init fail");
          Serial.println("Init CAN BUS again...");
          delay(100);
          goto START_INIT;
  // splash screen
  splash();
    CAN.init_Mask(0, 0, 0xFFC0000);
    CAN.init_Mask(1, 0, 0xFFC0000);
    CAN.init_Filt(0, 0, 0x8000000);   //0x200
    CAN.init_Filt(1, 0, 0x8140000);   //0x205
if(CAN_MSGAVAIL == CAN.checkReceive()) {           // check if data coming
    CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
    canId = CAN.getCanId();       // get CAN ID
      if(canId == 0x200){
        Serial.print("get data from ID: 0x");
        Serial.println(canId,HEX);
        temp = buf[4];
        data1 = (int)temp;
        temp = buf[3];
        pof = (int)temp;
      else if(canId == 0x205){
        temp = buf[1];
        voltage = ((float)temp)*25.6;
        temp = buf[0];
        voltage = voltage + (float)temp/10;
        temp = buf[3];
        temperaturemin = (int)temp;
        temp = buf[4];
        temperaturemax = (int)temp;
        temp = buf[5];
        voltagemin = ((float)temp)/50;
        temp = buf[6];
        voltagemax = ((float)temp)/50;
GLCD.SelectFont(CalBlk36);
GLCD.GotoXY(32,10);
GLCD.print(data1);
Hello... you might ne having troubles because of the volume of messages. You need to speedup your main loop.
First thing just make a timer to print how long your loop is taking. Print it every 10s example.
Now remove everything and just make a counter every time a CAN msg is available and print this counter every 10s as well.
My suspicion is that you're spending all time updating the LCD... so make a function the will only update if new data and define a max update rate, like every second.
Hello Musskopf,
you are right, I'm now updating the LCD values each 2s and everything works absolutely fine!
thank you very much!
Silvio
Great! By the way, which bike are you connecting to? I have on my ToDo list to connect a Talk2 RPi Hat to a F800R for some fun projects, especially to try to produce to visual alert (high bean and hazard lights) when I use the horn. Hopefully will find some time soon.
musskopf:
I'm not sure the F800R has a CAN connected headlight... I'm using my dashboard on a KTM Freeride-E (electric motocross bike) but I'm only visualizing data without sending anything new on the bus.
