The code for te sending MCP2515 is this:
// demo: CAN-BUS Shield, send data
// loovee@seeed.cc
#include <SPI.h>
/*SAMD core*/
#ifdef ARDUINO_SAMD_VARIANT_COMPLIANCE
#define SERIAL SerialUSB
#else
#endif
#define CAN_2515
// #define CAN_2518FD
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
// Set SPI CS Pin according to your hardware
// For Wio Terminal w/ MCP2518FD RPi Hat:
// Channel 0 SPI_CS Pin: BCM 8
// Channel 1 SPI_CS Pin: BCM 7
// Interupt Pin: BCM25
// For Arduino MCP2515 Hat:
// SPI_CS Pin: D9
#ifdef CAN_2518FD
#include "mcp2518fd_can.h"
const int SPI_CS_PIN = 10;
const int CAN_INT_PIN = 2;
mcp2518fd CAN(SPI_CS_PIN); // Set CS pin
#endif
#ifdef CAN_2515
#include "mcp2515_can.h"
mcp2515_can CAN(SPI_CS_PIN); // Set CS pin
#endif // Set CS pin
SERIAL.begin(115200);
while(!Serial){};
#ifdef CAN_2518FD
while (0 != CAN.begin((byte)CAN_500K_1M)) { // init can bus : baudrate = 500k
#else
while (CAN_OK != CAN.begin(CAN_500KBPS)) { // init can bus : baudrate = 500k
#endif
SERIAL.println("CAN BUS Shield init fail");
SERIAL.println(" Init CAN BUS Shield again");
delay(100);
SERIAL.println("CAN BUS Shield init ok!");
unsigned char stmp[8] = {0, 0, 0, 0, 0, 0, 0, 0};
// send data: id = 0x00, standrad frame, data len = 8, stmp: data buf
stmp[7] = stmp[7] + 1;
if (stmp[7] == 100) {
stmp[7] = 0;
stmp[6] = stmp[6] + 1;
if (stmp[6] == 100) {
stmp[6] = 0;
stmp[5] = stmp[6] + 1;
CAN.sendMsgBuf(0x00, 0, 8, stmp);
delay(100); // send data per 100ms
SERIAL.println("CAN BUS sendMsgBuf ok!");
// END FILE
And the code for te recieving module is:
// demo: CAN-BUS Shield, receive data with check mode
// send data coming to fast, such as less than 10ms, you can use this way
// loovee, 2014-6-13
#include <SPI.h>
/*SAMD core*/
#else
#endif
#define CAN_2515
// SPI_CS Pin: D9
#ifdef CAN_2518FD
#endif
#ifdef CAN_2515
#endif
#ifdef CAN_2518FD
#else
#endif
delay(100);
unsigned char len = 0;
unsigned char buf[8];
if (CAN_MSGAVAIL == CAN.checkReceive()) { // check if data coming
CAN.readMsgBuf(&len, buf); // read data, len: data length, buf: data buf
unsigned long canId = CAN.getCanId();
SERIAL.println("-----------------------------");
SERIAL.print("Get data from ID: 0x");
SERIAL.println(canId, HEX);
for (int i = 0; i < len; i++) { // print the data
SERIAL.print(buf[i], HEX);
SERIAL.print("\t");
SERIAL.println();
END FILE
I got htis code also from the website: arduino - MCP2515 CAN Transceivers can't go higher than 125kbps - Electrical Engineering Stack Exchange
I also used other programs and libraries, but here too I couldn't read anything on the CAN bus, so I wonder if I'm missing something in the circuit. Or is this circuit correct? The Arduino program is perfectly compilable. Maybe I did forget a part.
Kind regards Pieter Reynebeau
