Mcp2515 + errors
Hi. For three months I have been trying to friend mcp2515 to send data from arduino to PLC unitronics v570. The data is coming, we are transmitting pt100 sensors. But sometimes we see this picture:
The data goes and becomes 145.0 for literally a couple of seconds. Which causes a crash at the station and it stops.
The cause has not been determined for a month now.
Principle of exchange: Array of 127 data from sensors
PLC sends us for example 0, we send data from 0 array. and when it comes 1 ->1 and so on 127 times.
It should be noted that we have a backup channel of exchange via ethernet and here on it such problems are not observed. I understand that it is faster and so on, but here is such a problem. Maybe there are some ideas to solve this problem
(procedur send data)
 if (CAN.checkReceive() == CAN_MSGAVAIL) {
    CAN.readMsgBuf(&canId, &len, received_data); // Читаем данные
    mi_pos = received_data[0];
    bool valid_mi_pos = (mi_pos >= 0) && (mi_pos < 125) && (mi_pos % 4 == 0);
    if (valid_mi_pos) {
      // Отправляем текущее значение из массива MI
      short int value = MI[mi_pos]; // Берем текущее значение
      uint8_t pos = 0; // выбираем, куда в can_data поместить значение (возможные значения: 0, 2, 4, 6)
      memcpy(can_data + pos, &value, sizeof(short int));
      value = MI[mi_pos + 1]; // выбираем, показания датчика MAX
      pos = 2; // выбираем, куда в can_data поместить значение (возможные значения: 0, 2, 4, 6)
      value = MI[mi_pos + 2]; // выбираем, показания датчика MAX
      pos = 4; // выбираем, куда в can_data поместить значение (возможные значения: 0, 2, 4, 6)
      value = MI[mi_pos + 3]; // выбираем, показания датчика MAX
      pos = 6; // выбираем, куда в can_data поместить значение (возможные значения: 0, 2, 4, 6)
      // Отправляем данные
      if (CAN.sendMsgBuf(mi_pos, 0, 8, can_data) == CAN_OK) {
        //Serial.println("Send error");
this problem is observed only on pt100, we have acp sensors and they do not show this problem. pic
Please read and use the sticky post "How to get the best out of this forum".
Posting all of the code would help us help you. I have No idea of what the variables are or how they are defined.
