MCP3421
Hi all,
I am trying to interface MCP3421 with Arduino.
Hardware Setup:
SCL (MCP3421) – Analog 5 (Arduino)
SDA (MCP3421) – Analog 4(Arduino)
SCL & SDA pulled up using 1.1k resistor to 5V
Arduino Code
#include <Wire.h>
int addr = 0x34; //Tried 0x68 as well
int config;
byte U8_data;
byte L8_data;
Wire.begin();
delay(10);
Wire.beginTransmission(addr);
Wire.send(0xFB);
Wire.endTransmission();
Wire.requestFrom(addr, 1);
// wait until there is data to read
while(Wire.available() < 1)
Serial.print(“available:”);
Serial.println(Wire.available());
// now read it
U8_data = Wire.receive();
L8_data = Wire.receive();
config = Wire.receive();
Serial.print(“U8_data:”);
Serial.println(U8_data);
Serial.print(“L8_data:”);
Serial.println(L8_data);
Serial.print(“config:”);
Serial.println(config);
delay(10);
Its not working :frowning:
Kindly suggest what could be possibly wrong :-/
Thanks!
You're only requesting 1 byte from the chip, but trying to read 3.
You should also either make sure Wire.available() is >= 3 before you start reading, or wait until it's > 0 before each read, just to make sure that your code doesn't get ahead of your incoming data.
Good point!
I updated the code, but still no success.
#include <Wire.h>
int addr = 0x34;
int config;
int U8_data;
int L8_data;
Wire.begin();
delay(10);
Wire.send(0xFB);
// Wire.beginTransmission(addr);
// Wire.send(0b0001);
// Wire.endTransmission();
// delay(10);
Wire.requestFrom(addr, 3);
while(Wire.available() >= 3)
// now read it
delay(10);
Did you have any success? I would like to use the same component, but I don't really know where to start.
Serial.print("available:");
// now read it
While there is 3 or more bytes of data to read, do nothing. Then, report how much is available and read three bytes.
This does not work, huh? Can't say I'm surprised...
Here is a link to a demo sketch for the MCP342X ADCs
http://forums.adafruit.com/viewtopic.php?f=31&t=12269&p=76280&hilit=great+adc#p60335
Thank you very much! this totally fixed my problem in 5 minutes... turns out the last three bites of my address are not 000 (which should be the default setting) but 011, who knew. Thanks for the nice code.
