mcp4131 and attiny85
hey,
has anyone been able to get these two chips talking to each other? After many hours of trying every option google and this forum has suggested I haven't made much progress :/
sorry to be asking a question on my first post. Hi everyone!
What have you tried? Looks like all you need is this
int command_data;  upper 4-6 bits are command related, lower 10 are data
digitalWrite (CS, LOW);
SPI.transfer (highByte, (command_data) );
SPI.transfer (lowByte, (command_data) );
digitalWrite (CS, HIGH);
isn't that using the spi library? the attiny can't run it. i have tried using pulseout and USI. this guy managed to get four of them working with a multiplexer, i have tried to simplify his code as well --> http://fanjita.org/serendipity/archives/44-SPI-addressing-with-minimal-pins.html
In that case:
shiftout ( dataPin, clockPin, MSBFIRST, highByte (command_data) );
shiftout ( dataPin, clockPin, MSBFIRST, lowByte (command_data) );
Mmm, that code gives me back error messages from the tiny core. Have i formatted the code correctly?
#define CS     1
#define dataPin      3
#define clockPin 2
pinMode(CS, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
int  command_data;
shiftOut(dataPin, clockPin, MSBFIRST, highByte (command_data) );
shiftOut(dataPin, clockPin, MSBFIRST, lowByte (command_data) );
Thanks for the pointers mate :slight_smile:
Huh! I can't get it to compile for an Uno in 1.0 either! Something odd going on with #define, I had to change the pin definitions to this:
byte CS = 2;
byte dataPin  = 3;
byte clockPin  = 4;
int command_data = 0;
 // command_data = whatever it's being changed to
shiftOut (dataPin, clockPin, MSBFIRST, highByte (command_data) );
shiftOut (dataPin, clockPin, MSBFIRST, lowByte (command_data) );
int  command_data;
command_data, being a local variable, is not initialized by the compiler, and is never explicitly valued. So, why do you want to send garbage to the mcp4131?
As i want to control that variable with an analog input voltage [from a pot], i gather i could just replace command_data with 'val' and set that as the value i want.
That code certainly uploads onto the ATTing85 alright, just going to have a tinker with it. Thanks again :)
CrossRoads: Huh! I can't get it to compile for an Uno in 1.0 either! Something odd going on with #define, I had to change the pin definitions to this:
byte CS = 2;
byte dataPin  = 3;
byte clockPin  = 4;
pinMode(CS, OUTPUT); pinMode(dataPin, OUTPUT); pinMode(clockPin, OUTPUT);
void loop() { // command_data = whatever it's being changed to   digitalWrite (CS, LOW); shiftOut (dataPin, clockPin, MSBFIRST, highByte (command_data) ); shiftOut (dataPin, clockPin, MSBFIRST, lowByte (command_data) ); digitalWrite (CS, HIGH);
Works a treat!! Thanks!
PaulS:
int  command_data;
Its not necessary in this patch anyway, replacing it with val works fine.
EDIT:: I got it working!! crazy i spent so long to get an analog pot to fade an LED…
Here it is if anyone wants it
byte CS = 1;
byte dataPin  = 2;
byte clockPin  = 0;
byte analogPin  = 3;
int val = 0;
pinMode(analogPin, INPUT);
val = analogRead(analogPin);
val = map(val, 0,1024, 0,256);
shiftOut (dataPin, clockPin, MSBFIRST, highByte (val) );
shiftOut (dataPin, clockPin, MSBFIRST, lowByte (val) );
delay(4);
