MCP4131 with 8 - bit
Hello everybody
I am using MCP4131 with 7 - bit ( 0 - 128 ). Datasheet said that, it can work bit 7 and 8 bit and i definetly need to use it with 8 bit ( 0 - 256 ). Here is my code below;
#include <SPI.h>
byte address = 0x00;
int CS= 10;
pinMode (CS, OUTPUT);
SPI.begin();
digitalPotWrite(50);
int digitalPotWrite(int value)
digitalWrite(CS, LOW);
SPI.transfer(address);
SPI.transfer(value);
digitalWrite(CS, HIGH);
This is 7 bit code, to make it 8 bit. What shol i change in the code ? Ar what i need to do ?
Thank You
Best Regards
The datasheet says that the MCP4131 is a 7bit device. The MCP4151 is the corresponding 8bit device.
