Hi all
Posted a thread on the adafruit website.
Am starting to realize it maybe a programming mistake in that some rounding is occuring that might be keeping this providing the full range of analog values
can someone check if this is segment of code is logical
Seg2 comes from serial command.
int seg3= seg2.toInt();
dac.setVoltage((((seg3/1000)* 4095) / 5), false); //Set voltage to 1V
Serial.println(seg2); //CMD1 responce
MCP4725 Eval not responding to changes < 0.5V - adafruit industries
larger segment of code
#include <Wire.h>
#include <Adafruit_MCP4725.h>
Adafruit_MCP4725 dac;
#define digitalPin13 13 // Port 13 for reading the push button on the light field module
#define DAC_RESOLUTION (9) // Set this value to 9, 8, 7, 6 or 5 to adjust the resolution
#define potentiometerPin A1
//Interrupt Setup Variables
const int ledPin = LED_BUILTIN;
volatile unsigned long timer1_counter = 31250; // Preload value for 1 second interrupt
int x =0;
int interlockstate=0;
int pushbuttonlightfield=0;
int analogPin = A5;
int Thumb_Dimmer_Pin = A1;
int Thermo_Pin = A2;
int ledPinFlashY = 0;
int ledPinFlashG = 0;
int flashcount= 0;
int turnontrimpot = 0;
int onetime =0;
int timeouttime_default= 1000;
float voltagevalue=0;
float Thumbvoltagevalue=0;
float Thermovoltagevalue=0;
float trimpotlowerlimit = 3.0;
char delimiter = ',';
//ISR//float value = 100; //3035;
noInterrupts(); // Disable all interrupts during setup
Serial.begin(9600); //begin serial data
Serial.setTimeout(timeouttime_default) ; // set a short timeout otherwise it hold stale stuff for the next command
//Interrupt Setup
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = timer1_counter; // preload timer
TCCR1B |= (1 << WGM12); // CTC mode
TCCR1B |= (1 << CS12); // 256 prescaler
TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
interrupts(); // enable all interrupts
//This actually needs to be here but dont have it spit out an output
//It is initalizing the DAQ
//Serial.println(" MCP4725 Test");
if (dac.begin(0x62)) { //could be 0x60 or 0x62
//setup the LEDs to toggle blinking when PCB inserted
//software needs to turn this off
digitalWrite(digitalPin12, LOW); // turn off Yellow LED in filter module
digitalWrite(digitalPin10, LOW); // turn on Green LED on filter module
ledPinFlashY = 12;
ledPinFlashG = 10;
} // close setup
ISR(TIMER1_COMPA_vect) {
digitalWrite(ledPinFlashG, !digitalRead(ledPinFlashG)); // Example: Toggle LED
digitalWrite(ledPinFlashY, !digitalRead(ledPinFlashY)); // Example: Toggle LED
delay (500); //rev 3, delay to slow system down
//check if serial communication is avaiable
if (Serial.available() > 0) {
String rx_byte = Serial.readStringUntil('\n');
// Find the index of the first delimiter
// DIMM send string is "DIMM,1"
int firstDelimiterIndex = rx_byte.indexOf(delimiter);
String seg1 = rx_byte.substring(0, firstDelimiterIndex);
int secondDelimiterIndex = rx_byte.indexOf(delimiter, firstDelimiterIndex + 1);
String seg2 = rx_byte.substring(firstDelimiterIndex + 1, secondDelimiterIndex);
rx_byte.trim();
if (seg1 == "DIMM")
