MCP4725 help make analogue pot to output linear 0-5v analogue out of DAC on UNO
Hi Arduino Community I
Need help to complete code so that I get a 0-5v output.
Im no coder just copy paste and test is my limits..
#include <Wire.h>
#include <Adafruit_MCP4725.h>
Adafruit_MCP4725 dac;
#define DAC_RESOLUTION    (8)
int knockB;
void setup(void) {
  Serial.println("Hello!");
  dac.begin(0x62);
  Serial.println("0-5v analog output voltage");
void loop()  {
  float Knock =  knockB * (5.0 / 1023.0);
float knockSignal = map(knockB, 0, 1023, 0, 255);
Serial.println("0-5v analog voltage");// Serial.println(Knock);
  Serial.println(knockB);
  Serial.println(knockSignal);
knockB = analogRead(A2);
       dac.setVoltage(knockSignal, false);
I found this sine look up table generator, if only I knew how to implement it. Sine Look Up Table Generator Calculator
So it's time to learn it.
All you need is dac.setVoltage(), like this:
Instead of knockSignal output the values from your sine table.
