MCP4725 supports output servo
I would like to know if the MCP4725 supports output for servo, if yes how is the code?
What makes you think that it would support output for a servo ?
As far as I can see the MCP4725 is a Digital to Analogue converter and servos do not use an analogue signal
So how do I run the servo on the module?
As far as I know you can't
Why do you want to use that module ?
I want to run a servo on the ESP01 but due to limited pins I don't know what to use for the servo
What interfaces (SPI, I2C etc) does the ESP01 have, if any ?
ESP01 only has digital pins, i2c, gpio0, gpio1, gpio2, gpio3
I want to set the servo using the analog pin so it can know which way it is going
I know very little about the ESP01
Can you use the Servo library with it ?
What type of servo do you have?
Part number or type.
Servos can be either digital or analogue.
I need additional pins to connect the servo and L298N to the ESP01. When I use the TX RX Pin for the servo, the wifi won't work
MG905
No idea why you would want to use a DAC for the job.
Here is something which may help you.
(https://maker.pro/esp8266/projects/esp01-servo-motor-control-using-web-server-1)
