MCP4921 DAC, sine wave and variable frequency..?
Hello from Peckham in London UK. :slight_smile:
Aside from the Android controlled arduino synth I am working on I am also looking into ways of generating waveforms for synthesis using our friend. :0)
I am currently playing around with the MCP4921 12 bit DAC and have got a sine wave on my oscillloscope from this code:
// Example for the MCP49x1 *single* DACs
// For the dual MCP49x2 series, see the other bundled example sketch.
#include <SPI.h>         // Remember this line!
#include <DAC_MCP49xx.h>
#define STEPS 256
// The Arduino pin used for the slave select / chip select
#define SS_PIN 10
byte wavetable[STEPS] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 2, 2,
2, 3, 3, 4, 4, 5, 6, 6, 7, 8, 9, 9, 10, 11, 12, 13, 14, 15, 17,
18, 19, 20, 22, 23, 24, 26, 27, 29, 30, 32, 34, 36, 37, 39, 41
, 43, 45, 47, 49, 51, 54, 56, 58, 61, 63, 66, 68, 71, 74, 76, 79,
82, 85, 88, 91, 94, 97, 100, 103, 107, 110, 113, 116, 120, 123,
127, 130, 134, 137, 141, 144, 148, 152, 155, 159, 162, 166, 170,
173, 177, 180, 184, 187, 191, 194, 197, 201, 204, 207, 210, 213,
216, 219, 222, 225, 228, 230, 233, 235, 237, 239, 241, 243, 245,
246, 248, 249, 251, 252, 253, 253, 254, 255, 255, 255, 255, 255,
255, 255, 254, 253, 253, 252, 251, 249, 248, 246, 245, 243, 241,
239, 237, 235, 233, 230, 228, 225, 222, 219, 216, 213, 210, 207,
204, 201, 197, 194, 191, 187, 184, 180, 177, 173, 170, 166, 162,
159, 155, 152, 148, 144, 141, 137, 134, 130, 127, 123, 120, 116,
113, 110, 107, 103, 100, 97, 94, 91, 88, 85, 82, 79, 76, 74, 71,
68, 66, 63, 61, 58, 56, 54, 51, 49, 47, 45, 43, 41, 39, 37, 36, 34,
32, 30, 29, 27, 26, 24, 23, 22, 20, 19, 18, 17, 15, 14, 13, 12, 11,
10, 9, 9, 8, 7, 6, 6, 5, 4, 4, 3, 3, 2, 2, 2, 1, 1, 1, 0, 0, 0, 0, 0, 0};
volatile int indx=0;
volatile int mi=1;
// Set up the DAC.
// First argument: DAC model (MCP4901, MCP4911, MCP4921)
// Second argument: SS pin (10 is preferred)
// (The third argument, the LDAC pin, can be left out if not used)
DAC_MCP49xx dac(DAC_MCP49xx::MCP4921, SS_PIN);
  // Set the SPI frequency to 1 MHz (on 16 MHz Arduinos), to be safe.
  // DIV2 = 8 MHz works for me, though, even on a breadboard.
  // This is not strictly required, as there is a default setting.
  dac.setSPIDivider(SPI_CLOCK_DIV8         );
  // Use "port writes", see the manual page. In short, if you use pin 10 for
  // SS (and pin 7 for LDAC, if used), this is much faster.
  // Also not strictly required (no setup() code is needed at all).
  dac.setPortWrite(true);
// Output something slow enough that a multimeter can pick it up.
// For MCP4901, use values below (but including) 255.
// For MCP4911, use values below (but including) 1023.
// For MCP4921, use values below (but including) 4095.
 indx++;
  dac.output(wavetable[indx]);
  if (indx>=STEPS)
 indx=0;
Could anyone help me with how to change the frequency of the wave using either sensor or variable changes?
Google "phase accumulator"
Look in to PLL's and VCO as the source of the sine wave. You can get a PLL for about 40p +VAT.
Mark
What frequency range do you want to generate?
About 50Hz-12KHz...
I'm looking at a tutorial for the DUE here:
Some good stuff on the role of the phaseAccumulator. I'll see what I can glean from it..
Speaking of the DUE... Has anyone seen and/or ordered the DigiX board from Digistump?? :astonished:
$59... I have!! XD
If I send instead of the variable indx one PWM it should work?
