Hi Paul!
Code is here:
// Example for the MCP49x1 *single* DACs
// For the dual MCP49x2 series, see the other bundled example sketch.
#include <SPI.h>Â Â Â Â // Remember this line!
#include <DAC_MCP49xx.h>
#define STEPS 256
// The Arduino pin used for the slave select / chip select
#define SS_PIN 10
byte wavetable[STEPS] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 2, 2,
2, 3, 3, 4, 4, 5, 6, 6, 7, 8, 9, 9, 10, 11, 12, 13, 14, 15, 17,
18, 19, 20, 22, 23, 24, 26, 27, 29, 30, 32, 34, 36, 37, 39, 41
, 43, 45, 47, 49, 51, 54, 56, 58, 61, 63, 66, 68, 71, 74, 76, 79,
82, 85, 88, 91, 94, 97, 100, 103, 107, 110, 113, 116, 120, 123,
127, 130, 134, 137, 141, 144, 148, 152, 155, 159, 162, 166, 170,
173, 177, 180, 184, 187, 191, 194, 197, 201, 204, 207, 210, 213,
216, 219, 222, 225, 228, 230, 233, 235, 237, 239, 241, 243, 245,
246, 248, 249, 251, 252, 253, 253, 254, 255, 255, 255, 255, 255,
255, 255, 254, 253, 253, 252, 251, 249, 248, 246, 245, 243, 241,
239, 237, 235, 233, 230, 228, 225, 222, 219, 216, 213, 210, 207,
204, 201, 197, 194, 191, 187, 184, 180, 177, 173, 170, 166, 162,
159, 155, 152, 148, 144, 141, 137, 134, 130, 127, 123, 120, 116,
113, 110, 107, 103, 100, 97, 94, 91, 88, 85, 82, 79, 76, 74, 71,
68, 66, 63, 61, 58, 56, 54, 51, 49, 47, 45, 43, 41, 39, 37, 36, 34,
32, 30, 29, 27, 26, 24, 23, 22, 20, 19, 18, 17, 15, 14, 13, 12, 11,
10, 9, 9, 8, 7, 6, 6, 5, 4, 4, 3, 3, 2, 2, 2, 1, 1, 1, 0, 0, 0, 0, 0, 0};
volatile int indx=0;
volatile int mi=1;
// Set up the DAC.
// First argument: DAC model (MCP4901, MCP4911, MCP4921)
// Second argument: SS pin (10 is preferred)
// (The third argument, the LDAC pin, can be left out if not used)
DAC_MCP49xx dac(DAC_MCP49xx::MCP4921, SS_PIN);
 // Set the SPI frequency to 1 MHz (on 16 MHz Arduinos), to be safe.
 // DIV2 = 8 MHz works for me, though, even on a breadboard.
 // This is not strictly required, as there is a default setting.
 dac.setSPIDivider(SPI_CLOCK_DIV2);
Â
 // Use "port writes", see the manual page. In short, if you use pin 10 for
 // SS (and pin 7 for LDAC, if used), this is much faster.
 // Also not strictly required (no setup() code is needed at all).
 dac.setPortWrite(false);
// Output something slow enough that a multimeter can pick it up.
// For MCP4901, use values below (but including) 255.
// For MCP4911, use values below (but including) 1023.
// For MCP4921, use values below (but including) 4095.
indx+=4;
// dac.setSPIDivider(SPI_CLOCK_DIV2Â Â Â );
 dac.output(wavetable[indx]);
 if (indx>=STEPS)
indx=0;
Fairly standard stuff. Just a no-go on the MEGA2560. SCK, SDI and Vcc/Vss connected to ICSP. CS connected to pin 10. Vref to 5V…
