mcp49xx dac and wavetables?
I'd like to experiment with an 8-bit SPI DAC (MCP49X Library) and wave table to make some noises, but not sure where to start as much of the code I've seen is for R2C ladders.
I guess I could try to adapt from the r2c examples, has some one tried this and could share some advice?
thanks
A library will give you a function or method to call to output a value.
You need to, on a regular time step, write a value to the DAC using this function.
Something along the lines of:
unsigned long last_time = 0L;
  if (micros() - last_time >= DELAY)
    last_time += DELAY ;
    write_dac (table [index]) ;
    index = compute_next_index () ;
[ much left to be completed :slight_smile: ]
Do you not mean R2R ladders?
Look at the Adafruit wav shield code for examples of outputting to an SPI D/A.
