Hi all,
I'm currently trying some examples about acceleration measurement
The equipment I'm using are sparksfun accelerometer ADXL362 and arduino Due board. The protocol used in connection is SPI protocol and the example that I'm working on at the time is ADXL362 + Arduino: Using Interrupts to Implement Motion-Activated Sleep - Documents - MEMS Inertial Sensors - EngineerZone
Everytime I compile the code, an error message appears :
Arduino: 1.6.7 (Windows 10), Board: "Arduino Due (Programming Port)"
WARNING: library Low-Power-9692ae155b0395c1a0676c063995cf06fe761203 claims to run on [avr architecture(s) and may be incompatible with your current board which runs on samd] architecture(s).
In file included from C:\Users\M.Hussain\Documents\Arduino\libraries\annem-ADXL362-0e44374\libraries\Low-Power-9692ae155b0395c1a0676c063995cf06fe761203\Examples\standbyExternalInterruptSAMD21\standbyExternalInterruptSAMD21.ino:2:0:
C:\Users\M.Hussain\Documents\Arduino\libraries\annem-ADXL362-0e44374\libraries\Low-Power-9692ae155b0395c1a0676c063995cf06fe761203/LowPower.h:152:6: error: #error "Please ensure chosen MCU is ATSAMD21G18A."
exit status 1
Error compiling.
enabled in File > Preferences.
I tried to figure it out, I downloaded a modified version of the lowpower library but the same thing happened.
I need to know how it can be solved, or at least what "Please ensure chosen MCU is ATSAMD21G18A." means.
Thanks all,
