This is an MCU Friend 3.5" Shield
I have no idea what the LCD Driver is.... Any hints would be appreciated.
Alan www.iotexpert.com
Read Registers on MCUFRIEND UNO shield controllers either read as single 16-bit e.g. the ID is at readReg(0) or as a sequence of 8-bit values in special locations (first is dummy)
diagnose any controller reg(0x0000) 00 00 ID: ILI9320, ILI9325, ILI9335, ... reg(0x0004) 00 00 94 03 Manufacturer ID reg(0x0009) 00 00 61 00 00 Status Register reg(0x000A) 08 08 Get Powsr Mode reg(0x000C) 66 66 Get Pixel Format reg(0x0030) 00 00 00 00 00 PTLAR reg(0x0033) 00 00 00 00 00 00 00 VSCRLDEF reg(0x0061) 00 00 RDID1 HX8347-G reg(0x0062) 00 00 RDID2 HX8347-G reg(0x0063) 00 00 RDID3 HX8347-G reg(0x0064) 00 00 RDID1 HX8347-A reg(0x0065) 00 00 RDID2 HX8347-A reg(0x0066) 00 00 RDID3 HX8347-A reg(0x0067) 00 00 RDID Himax HX8347-A reg(0x0070) 00 00 Panel Himax HX8347-A reg(0x00A1) 00 00 00 00 00 RD_DDB SSD1963 reg(0x00B0) 00 00 RGB Interface Signal Control reg(0x00B3) 00 00 00 00 00 Frame Memory reg(0x00B4) 00 00 Frame Mode reg(0x00B6) 00 00 00 00 00 Display Control reg(0x00B7) 00 00 Entry Mode Set reg(0x00BF) 00 00 00 00 00 00 ILI9481, HX8357-B reg(0x00C0) 00 00 00 00 00 00 00 00 00 Panel Control reg(0x00C1) 00 00 00 00 Display Timing reg(0x00C5) 00 00 Frame Rate reg(0x00C8) 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA reg(0x00CC) 00 00 Panel Control reg(0x00D0) E0 E0 01 E0 Power Control reg(0x00D1) E1 E1 01 E1 VCOM Control reg(0x00D2) E0 E0 01 Power Normal reg(0x00D3) 00 00 94 03 ILI9341, ILI9488 reg(0x00D4) E1 E1 01 E1 Novatek reg(0x00DA) 00 00 RDID1 reg(0x00DB) 94 94 RDID2 reg(0x00DC) 03 03 RDID3 reg(0x00E0) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA-P reg(0x00E1) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA-N reg(0x00EF) 00 00 00 00 00 00 ILI9327 reg(0x00F2) 00 00 00 00 00 00 00 00 00 00 00 00 Adjust Control 2 reg(0x00F6) 00 00 00 00 Interface Control
