MCU Response Time for voltage surge detection
Hello again.
I've been trying to make this electronic surge protector based on an MCU. The basic principle I'm using is a voltage divider and the analog pins of an Arduino.
Obviously the 220V input will be scaled down to 5v then read on an analog pin. The code I'm writing is going to ping the analogPin every 10 millis or less and whenever the I/P voltage goes beyond, say 290 volts it just switches off a 2 pole contactor relay. No, issue there.
But here, as I've observed the vo
Admin, please remove this post, pressed the refresh button or something accidentally before completing the message :frowning:
The complete message has been re-posted.
vikramnayak: Admin, please remove this post, pressed the refresh button or something accidentally before completing the message :(
Where?
You can edit your posts you know, click on the modify tag and finish it off.
