I have a Mcufriend 2.4" TFT shield which I bought about a year ago. I didn't use it much after I bought it. But now I have a new project idea. I want to make a table lamp which can be controlled by a TFT touch screen like I bought earlier. so I took it again, attached with Arduino Uno and uploaded an example code that came with MCUFRIEND_kbv library called "button_simple". It didn't work well. The interface appeared without any kind of issue, but when I touch the screen to test it, the button on the interface wasn't working. So I uploaded a new example code which came with the same library called "TouchScreen_Calibr_native". After I uploaded that code, the screen showed a message like this.
Touch Calibration Failed
unable to read the position of the press.
This is a hardware issue and can not be corrected in software.
check XP, XM pins with a multimeter
check YP, YM pins with a multimeter
should be about 300 ohms.
And I don't know how to deal with this issue. Also, I figured out that there is a connection between two pins on TFT display which was connected to 3.3v pin and ground pin on Arduino after the TFT attached to Arduino. Is it ok to have connection between that pins?
I want to know, is this fixable or not and if it is fixable, how can I fix it. So I hope a great help for this issue.
