Hi. I have a MCUFRIEND 2.8 inch LCD shield with the ILI9341 that I have used
in the past, but now I want to use it with my newer NUCLEO-STM32G071 board.
I noticed that the G071 is not supported so I began to look into changing the
macro definitions to make it work.
I have gotten this far, and have included my work below, but I thing I'm stuck in the weeds and would appreciated anyone with detailed knowledge to find out what else do I have to edit.
David Prentice comes to mind, he's always providing solutions.
Also sorry for the dump of macro code, but I'm still trying to work out how to format this.
Thanks.
kv.
#define WR_ACTIVE2 {WR_ACTIVE; WR_ACTIVE;}
#define WR_ACTIVE4 {WR_ACTIVE2; WR_ACTIVE2;}
#define WR_ACTIVE8 {WR_ACTIVE4; WR_ACTIVE4;}
#define RD_ACTIVE2 {RD_ACTIVE; RD_ACTIVE;}
#define RD_ACTIVE4 {RD_ACTIVE2; RD_ACTIVE2;}
#define RD_ACTIVE8 {RD_ACTIVE4; RD_ACTIVE4;}
#define RD_ACTIVE16 {RD_ACTIVE8; RD_ACTIVE8;}
#define WR_IDLE2 {WR_IDLE; WR_IDLE;}
#define WR_IDLE4 {WR_IDLE2; WR_IDLE2;}
#define RD_IDLE2 {RD_IDLE; RD_IDLE;}
#define RD_IDLE4 {RD_IDLE2; RD_IDLE2;}
#define REGS(x) x
#define PIN_HIGH(port, pin) (port)-> REGS(BSRR) = (1<<(pin))
#define PIN_LOW(port, pin) (port)-> REGS(BSRR) = (1<<((pin)+16))
#define PIN_MODE2(reg, pin, mode) reg=(reg&~(0x3<<((pin)<<1)))|(mode<<((pin)<<1))
#define GROUP_MODE(port, reg, mask, val) {port->REGS(reg) = (port->REGS(reg) & ~(mask)) | ((mask)&(val)); }
// mod this for starters STM32F091xC
#define WRITE_DELAY { }
#define READ_DELAY { RD_ACTIVE; }
#define GPIO_INIT() { RCC->AHBENR |= RCC_IOPENR_GPIOAEN | RCC_IOPENR_GPIOBEN | RCC_IOPENR_GPIOCEN; }
#define PIN_OUTPUT(port, pin) PIN_MODE2((port)->MODER, pin, 0x1)
// Uno Shield on NUCLEO-64 STM32G071
#define RD_PORT GPIOA //PA0
#define RD_PIN 0
#define WR_PORT GPIOA //PA1
#define WR_PIN 1
#define CD_PORT GPIOA //PA4
#define CD_PIN 4
#define CS_PORT GPIOB //PB1
#define CS_PIN 1
#define RESET_PORT GPIOB //PB11
#define RESET_PIN 11
#define AMASK ((1<<9)|(1<<10)|(1<<8)) // Data Bus bit positions: #0, #2, #7
#define BMASK ((1<<3)|(1<<5)|(1<<4)|(1<<14)) // Data Bus bit positions: #3, #4, #5, #6
#define CMASK ((1<<7)) // Data Bus bit positions: #1
#define write_8(d) {
GPIOA->REGS(BSRR) = AMASK << 16;
GPIOB->REGS(BSRR) = BMASK << 16;
GPIOC->REGS(BSRR) = CMASK << 16;
GPIOA->REGS(BSRR) = ( ((d) & (1<<0)) << 9)
| (((d) & (1<<2)) << 8)
| (((d) & (1<<7)) << 1);
GPIOB->REGS(BSRR) = ( ((d) & (1<<3)) << 0)
| (((d) & (1<<4)) << 1)
| (((d) & (1<<5)) >> 1)
| (((d) & (1<<6)) << 8);
GPIOC->REGS(BSRR) = ( ((d) & (1<<1)) << 6);
#define read_8() ( ( ( (GPIOA->REGS(IDR) & (1<<9)) >> 9)
| ((GPIOC->REGS(IDR) & (1<<7)) >> 6)
| ((GPIOA->REGS(IDR) & (1<<10)) >> 8)
| ((GPIOB->REGS(IDR) & (1<<3)) >> 0)
| ((GPIOB->REGS(IDR) & (1<<5)) >> 1)
| ((GPIOB->REGS(IDR) & (1<<4)) << 1)
| ((GPIOB->REGS(IDR) & (1<<14)) >> 8)
| ((GPIOA->REGS(IDR) & (1<<8)) >> 1)))
#define setWriteDir() { setReadDir();
GPIOA->MODER |= 0x150000; GPIOB->MODER |= 0x10000540; GPIOC->MODER |= 0x4000; }
#define setReadDir() { GPIOA->MODER &= ~0x3F0000; GPIOB->MODER &= ~0x30000fc0; GPIOC->MODER &= ~0xC000; }
#ifndef IDLE_DELAY
#define IDLE_DELAY { WR_IDLE; }
#endif
#define write8(x) { write_8(x); WRITE_DELAY; WR_STROBE; IDLE_DELAY; }
#define write16(x) { uint8_t h = (x)>>8, l = x; write8(h); write8(l); }
#define READ_8(dst) { RD_STROBE; READ_DELAY; dst = read_8(); RD_IDLE2; RD_IDLE; }
#define READ_16(dst) { uint8_t hi; READ_8(hi); READ_8(dst); dst |= (hi << 8); }
#define RD_ACTIVE PIN_LOW(RD_PORT, RD_PIN)
#define RD_IDLE PIN_HIGH(RD_PORT, RD_PIN)
#define RD_OUTPUT PIN_OUTPUT(RD_PORT, RD_PIN)
#define WR_ACTIVE PIN_LOW(WR_PORT, WR_PIN)
#define WR_IDLE PIN_HIGH(WR_PORT, WR_PIN)
#define WR_OUTPUT PIN_OUTPUT(WR_PORT, WR_PIN)
#define CD_COMMAND PIN_LOW(CD_PORT, CD_PIN)
#define CD_DATA PIN_HIGH(CD_PORT, CD_PIN)
#define CD_OUTPUT PIN_OUTPUT(CD_PORT, CD_PIN)
#define CS_ACTIVE PIN_LOW(CS_PORT, CS_PIN)
#define CS_IDLE PIN_HIGH(CS_PORT, CS_PIN)
#define CS_OUTPUT PIN_OUTPUT(CS_PORT, CS_PIN)
#define RESET_ACTIVE PIN_LOW(RESET_PORT, RESET_PIN)
#define RESET_IDLE PIN_HIGH(RESET_PORT, RESET_PIN)
#define RESET_OUTPUT PIN_OUTPUT(RESET_PORT, RESET_PIN)
// General macros. IOCLR registers are 1 cycle when optimised.
#define WR_STROBE { WR_ACTIVE; WR_IDLE; } //PWLW=TWRL=50ns
#define RD_STROBE RD_IDLE, RD_ACTIVE, RD_ACTIVE, RD_ACTIVE //PWLR=TRDL=150ns, tDDR=100ns
#if !defined(GPIO_INIT)
#define GPIO_INIT()
#endif
#define CTL_INIT() { GPIO_INIT(); RD_OUTPUT; WR_OUTPUT; CD_OUTPUT; CS_OUTPUT; RESET_OUTPUT; }
#define WriteCmd(x) { CD_COMMAND; write16(x); CD_DATA; }
#define WriteData(x) { write16(x); }Use code tags to format code for the forum
