Hi Everybody.
I am using this:
UNO with 2.4 TFT touch shield.
Aduino ide 1.8.12.
All the samples works fine , but in this small sketch the cursor values only works in the first loop.
First loop:prints (value2) then prints sevensegment font "1234"
Then there is about 8 seconds that nothing is printed then a massive big "0" sevensegment digit is printed on the screen.
Thanks for any advice.
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
#include <SPI.h> // f.k. for Arduino-1.5.2
#include "Adafruit_GFX.h"// Hardware-specific library
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
//#include <Adafruit_TFTLCD.h>
//Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
#include <FreeDefaultFonts.h>
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSans12pt7b.h>
#include <Fonts/FreeSerif12pt7b.h>
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
int value2 = 0;
void showmsgXY(int x, int y, int sz, const GFXfont *f, const char *msg)
int16_t x1, y1;
uint16_t wid, ht;
// tft.drawFastHLine(0, y, tft.width(), WHITE);
tft.setFont(f);
tft.setCursor(x, y);
tft.setTextColor(GREEN);
tft.setTextSize(sz);
tft.print(msg);
void setup(void) {
uint32_t when = millis();
// while (!Serial) ; //hangs a Leonardo until you connect a Serial
if (!Serial) delay(5000); //allow some time for Leonardo
Serial.println("Serial took " + String((millis() - when)) + "ms to start");
// tft.reset(); //hardware reset
uint16_t ID = tft.readID(); //
Serial.print("ID = 0x");
Serial.println(ID, HEX);
if (ID == 0xD3D3) ID = 0x9481; // write-only shield
// ID = 0x9329; // force ID
tft.begin(ID);
tft.fillScreen(BLACK);
void loop(void)
value2 = value2 + 1;
tft.setTextSize(4);
tft.setTextColor(RED, BLACK);
tft.setCursor(50, 10);
tft.println(value2); //
//when "showmsgxy" is commented out the code works fine.
showmsgXY(5, 180, 1, &FreeSevenSegNumFont, "1234");
