I have bought the cheap 8x8 LED matrix from Amazon. I have researched the HARDWARE issues with the library MD_MAX72xx.h and found one that somewhat works (and believe me I have tried them all) but NONE of them allow the sucessful use of the setBuffer() function. Has anybody had this problem and found a good solution? My present work around is the make a function called pushBuffer that is just basically calling setPoint() 64 times to send my buffer array.
[UPDATED]
I hope this is correct to guidelines.
So as the code shows I have chosen the top hardware definition but I have tried them all. All the happens is either top row or bottom row or left column or right column is lit on the display when I comment in other HW defintions (photo shows left column lit). The buffer is set to all '1's which should be all LED's on the display on after the call to mx.setBuffer(). I made the example code here a simple as possible to show problem.
Thanks,
Bob
// Including the required Arduino libraries
#include <MD_MAX72xx.h>
#include <SPI.h>
#define HARDWARE_TYPE MD_MAX72XX::DR0CR0RR0_HW
// #define HARDWARE_TYPE MD_MAX72XX::DR0CR0RR1_HW
// #define HARDWARE_TYPE MD_MAX72XX::DR0CR1RR0_HW //(GENERIC_HW)
// #define HARDWARE_TYPE MD_MAX72XX::DR0CR1RR1_HW
// #define HARDWARE_TYPE MD_MAX72XX::DR1CR0RR0_HW //(FC16_HW)
// #define HARDWARE_TYPE MD_MAX72XX::DR1CR0RR1_HW
// #define HARDWARE_TYPE MD_MAX72XX::DR1CR1RR0_HW //(PAROLA_HW)
// #define HARDWARE_TYPE MD_MAX72XX::DR1CR1RR1_HW //(ICSTATION_HW)
#define MAX_DEVICES 1
#define CLK_PIN 13 // or SCK
#define DATA_PIN 11 // or MOSI
#define CS_PIN 3 // or SS
uint8_t buffer[8] = {
0b11111111,
0b11111111,
0b11111111,
0b11111111,
0b11111111,
0b11111111,
0b11111111,
0b11111111
// Create a new instance of the MD_MAX72XX class
MD_MAX72XX mx = MD_MAX72XX(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
pinMode(CLK_PIN , OUTPUT);
pinMode(DATA_PIN , OUTPUT);
pinMode(CS_PIN , OUTPUT);
// Initialize the display
mx.begin();
// Set the intensity (brightness) of the display (0-15)
mx.control(MD_MAX72XX::INTENSITY, 7);
// Clear the display
mx.clear(0);
mx.setBuffer(0,8,buffer);
Hi, I am not using (or want to) the paroloa library, I will not be scrolling and do not need a font library. I am using MD_MAX72xx.h. In order for the setPoint() to work properly, I had to use the DR0CR0RR0 hardware defintion for the specific display I bought from Amazon. The problem is in using the setBuffer() function, that does not work or not properly. The best I ever got was if I defined all bytes in buffer[] to
be 0b11111111 , after calling setBuffer(buffer), only the top row of display would be lit.
Basically there are rules re code, errors, wiring that if are followed will give you the best result, If not then it will take much longer.
I strongly suggest you start at square one, having to mangle the setBuffer function is a big clue that something basic is wrong, maybe a wrong library?
im sorry I am too mortified to post as I believe everything I do will not be in guidelines but I did uou exeample code from where you say MajicDesigns/MD_MAX72XX · GitHub
Think about what a helper needs to see. Do you think I care about seeing the UNO or a CLEAR picture of what wire goes in what pin? We need to see all the wires, especially when there are two whites and two purples. We actually prefer you to hand-draw where the wires go, then take a picture of the drawing. Right now, the picture is not useful.
Your original setBuffer() was sending the zeroth element in the array, only. I found this by playing with the bits in your buffer (see below), which lead me to the setBuffer() call, then to the first argument in setBuffer() call which (when walking 0 through 7) I found to have an effect.
#include <SPI.h>
uint8_t buffer[8] = { // EDITED SOME BITS
0b01111111,
0b10111111,
0b11011111,
0b11101111,
0b11110111,
0b11111011,
0b11111101,
0b11111110
pinMode(CLK_PIN, OUTPUT);
pinMode(DATA_PIN, OUTPUT);
pinMode(CS_PIN, OUTPUT);
mx.begin();
for (int i = 0; i < 8; i++) {
mx.setBuffer(i, 8, buffer); // change this
delay(250);
mx.clear();
Thank you! Your post indirectly gave me the answer. Let me share. First off though, I would never call setBuffer() 8 times, once per column as that is not it's intention. It is made to transfer an entire 8 bytes (64 bits) to the display at one time as described here :https://majicdesigns.github.io/MD_MAX72XX/class_m_d___m_a_x72_x_x.html#a1aaabf8c4df556c3e9a04a1319234261
Calling it 8 times would defeat its purpose and use valuable processing clock cycles and there is another function setColumn() that is made for that specific thing. Now, the definition of the parameters for the setBuffer() call from above link is quite misleading to me "col address of the start display column [0..[getColumnCount()]" and I could see where it suggested calling it the number of columns times. I just assumed 0 as that is logically the column from where I wish start. But your code inspired my to play with this parameter and discovered the answer. The following code line works: setBuffer(7,8,buffer). This copies the entire buffer to the screen display in one shot which I have tested with various buffer patterns sucessfully.
I have no idea why but the end result is what I have been trying for. Thanks again for the catalyst!
