MD_UISwitch library: anyone has experience with it
Hello
I'm trying to use the MD_UISwitch library to decode analog switch. I'm experiencing some debounce. I'm using ESP12f (ESP8266) processor
How could I modify the timing of the library? sometime, A short press is decode like a long press and multiple reading for a single press.
3 single short keypress on button#2 is resulting to
Key_UP 2
LongP 2
Key_UP 2
Key_UP 2
LongP 2
Key_UP 2
My code is extract from the exemple
Martin
// Example showing use of the MD_UISwitch library
// Exercises different types of UI switches
// Prints the switch value on the Serial Monitor
// Allows setting of options to see their effect (see setup())
#include <MD_UISwitch.h>
#define TEST_ANALOG  1
#if TEST_ANALOG
#define TITLE "Analog Input"
const uint8_t ANALOG_SWITCH_PIN = A0;       // switches connected to this pin
// These key values work for most LCD shields
MD_UISwitch_Analog::uiAnalogKeys_t kt[] =
  //{  12, 10, 'R' },  // Right
  { 30, 10, '4' },  // Up
  { 82, 15, '3' },  // Down
  { 293, 15, '2' },  // Left
  { 1024, 15, '1' },  // Select
MD_UISwitch_Analog S(ANALOG_SWITCH_PIN, kt, ARRAY_SIZE(kt));
#endif
void setup(void)
  Serial.begin(57600);
  S.begin();
  //S.enableDoublePress(false);
  S.enableLongPress(true);
  //S.enableRepeat(false);
  //S.enableRepeatResult(true);
void loop(void)
  MD_UISwitch::keyResult_t k = S.read();
  if (k != MD_UISwitch::KEY_NULL)
    if (S.getKey() >= ' ')
      if (k == MD_UISwitch::KEY_LONGPRESS)
        Serial.print("LongP ");
        Serial.println((char)S.getKey());
      //Serial.print(" ");
      if (k == MD_UISwitch::KEY_DPRESS)
        Serial.print("Depr ");
      if (k == MD_UISwitch::KEY_UP)
        Serial.print("Key_UP ");
There is extensive documentation for this library in folder where it is located. There are methods to set the timing and disable/enable all the different press types.
