MDB USART mystery
Hello!
I have connected an UNO R3 to a circuit desribed in the NAMA MDB 4.2 standard so that I can “talk” to a vending machine.
void init_MDB() {
  // Set baud rate
  UBRR0H = UBRRH_VALUE;
  UBRR0L = UBRRL_VALUE;
  // Disable USART rate doubler (arduino bootloader leaves it enabled...)
  UCSR0A &= ~(1 << U2X0);
  // Set asynchronous
  UCSR0C = (0<<UMSEL01)|(0<<UMSEL00);
  // set 1 stop bit
  UCSR0C |= (0<<USBS0);
  // set no parity
  UCSR0C |= (0<<UPM01)|(0<<UPM00);
  // set 9bit
  UCSR0C |=(1<<UCSZ01)|(1<<UCSZ00);
  UCSR0B |= (1<<UCSZ02);
  UCSR0B |= (1<<RXEN0);  // Enable RX
  //UCSR0B |= (1<<TXEN0);  // Enable TX
I can receive data just fine. When I try to enable transmission
The vending machine goes into “out of service” mode. I am not sending anything. The only thing I’ve done is enable this bit.
Is it possible that the arduino is transmitting and I don’t know it? Maybe TX is set to HIGH or something?
Should I disable TX while I don’t need it?
Will toggling it at run time introduce noise to the network and screw things up?
Thank you.
