MDD10A motor driver operating current
Hello
I am currently in the middle of my senior project, and I chose the MDD10A motor driver to supply the required voltage and current to my gear motor.
However I can't seem to find the operating current, or the input current that the motor driver needs from the battery.
I looked at all the data sheets for this driver and I can only find the maximum current that it supplies.
Any help would be appreciated.
Min voltage 5V, max voltage 25V, max current 10A (30A peak). All the information needed is in the manual.
You need to find out the voltage your motor needs, choose a power supply to match. The current
will be a function of the motor and how loaded it is.
If the motor’s stall current is higher than 30A at the supply voltage chosen, it is not suitable for this
motor driver.
