I am trying to follow a youtube video of how to edit the MDMax72xx.h file for my hardware so that i can try some MDParola examples, the file in the video looks nothing like mine and is slightly confusing as he is using an editor without line numbers, i will post a picture of my file which shows hardware types but none of them are commented out, any help appreciated...
* USE_LOCAL_FONT is set to 1.
* \return pointer to the start of the font table in PROGMEM.
fontType_t *getFont(void) { return(_fontData); };
#endif // USE_LOCAL_FONT
private:
typedef struct
uint8_t dig[ROW_SIZE]; // data for each digit of the MAX72xx (DIG0-DIG7)
uint8_t changed; // one bit for each digit changed ('dirty bit')
} deviceInfo_t;
// LED module wiring parameters defined by hardware type
moduleType_t _mod; // The module type from the available list
bool _hwDigRows; // MAX72xx digits are mapped to rows in on the matrix
bool _hwRevCols; // Normal orientation is col 0 on the right. Set to true if reversed
bool _hwRevRows; // Normal orientation is row 0 at the top. Set to true if reversed
// SPI interface data
uint8_t _dataPin; // DATA is shifted out of this pin ...
uint8_t _clkPin; // ... signaled by a CLOCK on this pin ...
uint8_t _csPin; // ... and LOADed when the chip select pin is driven HIGH to LOW
bool _hardwareSPI; // true if SPI interface is the hardware interface
