Me again! Ultrasonic sensor issues
My project is continuing and the hardware is done, but the software for my ultrasonic sensor isn't measuring properly. It compiles, downloads, and does everything right, except the only distance it prints is "Distance in cm: 357". Every time. This isn't my code used inside of also not my code. It uses the ultrasonic library to measure distance.
int buttonValue;
int previous = HIGH;
int pin = 2;
int screenNumber = 0;
#include <LiquidCrystal.h>
#include <Ultrasonic.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 8, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
Ultrasonic ultrasonic(7,6);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  pinMode(13, INPUT_PULLUP);
  buttonValue = digitalRead(13);
  if (buttonValue == LOW && previous == HIGH)  // Has a button just been pressed?
    switch (screenNumber)                      // Select the screen to display.
      case 0:
        lcd.clear();
        lcd.print("Joystick control");  // joystick and rgb led page
      case 1:
        lcd.clear();
        lcd.print("Humidity/Temp");    // dht11 temp/humidity module page
      case 2:
        lcd.clear();
        lcd.print("Light level");       // photoresistor page
      case 3:
        lcd.clear();
        lcd.print("Distance");        // ultrasonic sensor page
        lcd.clear();                           // Clears the screen in preparation of new measurement
  lcd.print("Distance in cm:");           // Prints the first line of the display
  lcd.setCursor(0,1);                     // Moves cursor tot he second line of display
  lcd.print(ultrasonic.distanceRead());   // Takes measurement from US and prints it to LCD
      case 4:
        lcd.clear();
        lcd.print("IR control");          // infrared controller page
    screenNumber = (screenNumber + 1 ) % 5;    // Calculate the next screen number
  previous = buttonValue;
Can I get that in English, please?
Have you tried a simple sketch that just prints the ranges?
Mb I fixed it lol
What's that?
It stands for my bad
