Meaning of "if ((PINB & _BV(BUTTON_PIN)) == 0) {"
I am trying to understand the following project: blog/main.c at master · lpodkalicki/blog · GitHub.
With respect to
a && is AND so what is a single &, also what does the _ mean?
Is it saying something like, "if (PINB and Button) pressed then ......."?
&& is boolean AND. It adds more elements to a test for true/false so you can say
if (this == true && that == true)
     //execute code here if both are true
& is bitwise AND and is used to compare individual bits so you can say
byte a = 0b00000001;
byte b = 0b00000001;
byte c = 0b00000010;
byte d = a & b;  //the result is 0b00000001 because both have a 1 in bit 0
byte e = a & c;  //the result is 0b00000000  because no bits have 1 in both
The _ has no meaning. It is part of the name of a defined value and is used to help prevent the same name being used as a variable or #defined value by a user in a sketch. The _BV macro is defined as part of the Arduino system and returns a value with the single bit set by the value supplied
You may be interested to try this
  while (!Serial);
  for (byte x = 0; x < 8; x++ )
    printFullBin(_BV(x));
void printFullBin(byte value)
  for (int bit = 7; bit > 0; bit--)
    Serial.print(bitRead(value, bit));
Many thanks for that explanation.
I might battle to discribe what I am trying to achieve but here goes.
I am wanting to take blog/main.c at master · lpodkalicki/blog · GitHub. and modify it so that instead of activating the timer when a button is pressed, the timer is activated by a cetain analogRead value.
As a result of some googling, I have added the following code in order to set button pin to an analogue input
/* ADDED */
int analogData;       //declare analogData variable
And in at the top of timer_init
/* ADDED */
  ADMUX |= (1 << REFS0);   //use internal reference voltage of 1.1V (https://www.instructables.com/id/ATTiny-Port-Manipulation-Part-2-AnalogRead/)
  ADMUX |= (1 << MUX0);   //combined with next line…
  ADMUX |= (0 << MUX1);   //sets ADC2 as analog input channel
  ADMUX |= (1 << ADLAR);   //Left Adjust the ADCH and ADCL registers; 8 bit resolution
  ADCSRA = 0b10000011;  //turn on ADC, keep ADC single conversion mode,
  //and set division factor-8 for 125kHz ADC clock
  ADCSRA = 0b10000011;  //turn on the ADC, keep ADC single conversion mode
  //set division factor-8 for 125kHz ADC clock
I am not sure if I have applied the above correctly or if it contraticts some of the code later on.
If the above is correct then i am not sure how to alter the following code in timer_process
  if ((PINB & _BV(BUTTON_PIN)) ==0) {
    _delay_ms(10); // time for debounce
    while ((PINB & _BV(BUTTON_PIN)) ==0);
So that instead of checking for a button being pressed that it triggers when a particualr value or value range is read. I am wanting to do this using Port Manipulation as I am trying to get my code to fit on an ATTiny13.
I missed that I need the following:
  ADCSRA |= (1 << ADSC);         //start conversion
           analogData = ADCH;             //store data in analogData vari
I am guessing that I then change the following code
    while ((PINB & _BV(BUTTON_PIN)) == 0);
to something like
  if (analogdata >= "some desired value") {
    while (analogdata >= "some desired value");
