Measure air pressure via bluetooth
Hello,
I am running this code to measure air pressure via bluetooth and powering the Nano BLE 33 with 3.7v battery, when I remove while (!Serial) from the code I can see the bluetooth name at the device list but I cannot connect to the BLE to read the data? any idea what is going on here
#include <ArduinoBLE.h>
#include <Arduino_LPS22HB.h>
// Create a custom BLE service
BLEService pressureService("180F"); // Custom BLE service UUID
// Create a BLE float characteristic for the pressure data
BLEFloatCharacteristic pressureCharacteristic("2A6D", BLERead | BLENotify);
while (!Serial);
// Initialize the pressure sensor
if (!BARO.begin()) {
Serial.println("Failed to initialize pressure sensor!");
while (1);
// Initialize BLE
if (!BLE.begin()) {
Serial.println("Starting BLE failed!");
while (1);
// Set the local name for the BLE device
BLE.setLocalName("Nano33BLE");
// Set up the BLE service and characteristic
BLE.setAdvertisedService(pressureService);
pressureService.addCharacteristic(pressureCharacteristic);
BLE.addService(pressureService);
// Start advertising the BLE service
BLE.advertise();
Serial.print("Peripheral device MAC: ");
Serial.println(BLE.address());
Serial.println("Waiting for connections...");
// Wait for a BLE central device to connect
BLEDevice central = BLE.central();
if (central) {
Serial.print("Connected to central MAC: ");
Serial.println(central.address());
while (central.connected()) {
  // Read the pressure value in kPa
  float pressure = BARO.readPressure();
  // Update the BLE characteristic with the pressure value
  pressureCharacteristic.writeValue(pressure);
  // Print the pressure value for debugging purposes
  Serial.print("Atmospheric Pressure = ");
  Serial.print(pressure);
  Serial.println(" kPa");
  delay(1000);  // Wait 1 second before sending the next reading
Serial.print("Disconnected from central MAC: ");
You must put code and errors in < CODE > blocks. This helps you by making the code readable. This is what your code must look like:
  while (!Serial);
    while (1);
  // Initialize BLE
  if (!BLE.begin()) {
    while (1);
  BLE.advertise();
  if (central) {
Describe what you expect to see and your observations.
What are you using for the central device?
