Measure and display voltage on I2C LCD
I am frustrated that I can't read/display a dc voltage on Analog Pin 0.
Any idea where am going wrong? The LCD displays text as expected - just cant seem to display voltage.
 #include <WString.h>
#include <Wire.h>
int inputVoltagePin = 0; //int batt volts = input pin 0;
int lcd = 40;
void lcd2s_init()
delay(300);
Wire.beginTransmission (lcd); // transmit to device 0x50
Wire.send (0x8C); // send lcd clear command
Wire.endTransmission (); // stop transmitting
Wire.send (0x28); // turn B/light ON
delay(300);
void setup ()
Wire.begin();
lcd2s_init();
Wire.beginTransmission(lcd); // transmit to device 0x50
Wire.send (0x80); // ready to move cursor to location given by next byte
Wire.send ("Battery Volts =\n");//dispaly volts on next line
Wire.endTransmission(); // stop transmitting
void loop ()
  delay(300);
   // read voltage value
  int voltage = analogRead(inputVoltagePin);
  int valueVolts=voltage;
Wire.send (valueVolts);
delay (6000);
Wire.send (0x20);//backlight off
Do you need to convert your reading to ASCII?
("itoa()")
[edit]The "send(int)" method in "Wire" simply casts the supplied "int" to "uint8_t" and call the "send(uint8_t)" method, which is not what you want.[/edit]
Thanks for the reply. I sort of understand. I need to convert the ADC value to ASCII and send that to the LCD. If only I knew how?
Using itoa and or float statements have got me lost. Any suggestions of sample code? I'm sure reading the ADC and displaying the results via I2C as a voltage has been done before.
Did you ever figure this out? If you did, could you post the code for it? Thanks.
