Measure Dispensed Water, repeat with push button
Do you need to display the flowrate? If not, you don't need all this code.
The OP's code auto formatted.:
Liquid flow rate sensor -DIYhacking.com Arvind Sanjeev Measure the liquid/water flow rate using this code. Connect Vcc
and Gnd of sensor to arduino, and the signal line to arduino digital pin 2.
byte statusLed = 13;
byte sensorInterrupt = 0;
// 0 = digital pin 2
byte sensorPin = 2;
int val = 0;
// put your button on pin 4
const int startpin = 4;
int buttonState = 0;
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per
// litre/minute of flow.
float calibrationFactor = 4.5;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
  // Initialize a serial connection for reporting values to the host
  Serial.begin(38400);
  // Set up the status LED line as an output
  pinMode(statusLed, OUTPUT);
  // put your relay on pin 5
  pinMode(5, OUTPUT);
  pinMode(startpin, INPUT_PULLUP);
  digitalWrite(statusLed, HIGH);
  // We have an active-low LED attached
  pinMode(sensorPin, INPUT);
  digitalWrite(sensorPin, HIGH);
  pulseCount = 0;
  flowRate = 0.0;
  flowMilliLitres = 0;
  totalMilliLitres = 0;
  oldTime = 0;
  // The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
  // Configured to trigger on a FALLING state change (transition from HIGH
  // state to LOW state)
  attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
/** * Main program loop */
  // read the input pin:
  int buttonState = digitalRead(startpin);
  // fill button start if relay turn off
  if (digitalRead(5) == LOW)
  { val = digitalRead(startpin);
    digitalWrite(5, val);
  if ((millis() - oldTime) > 1000)
    // Only process counters once per second
    // Disable the interrupt while calculating flow rate and sending the value to
    // the host
    detachInterrupt(sensorInterrupt);
    // Because this loop may not complete in exactly 1 second intervals we calculate
    // the number of milliseconds that have passed since the last execution and use
    // that to scale the output. We also apply the calibrationFactor to scale the output
    // based on the number of pulses per second per units of measure (litres/minute in
    // this case) coming from the sensor.
    flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
    // Note the time this processing pass was executed. Note that because we’ve
    // disabled interrupts the millis() function won’t actually be incrementing right
    // at this point, but it will still return the value it was set to just before
    // interrupts went away.
    oldTime = millis();
    // Divide the flow rate in litres/minute by 60 to determine how many litres have
    // passed through the sensor in this 1 second interval, then multiply by 1000 to
    // convert to millilitres.
    flowMilliLitres = (flowRate / 60) * 1000;
    // Add the millilitres passed in this second to the cumulative total
    totalMilliLitres += flowMilliLitres;
    unsigned int frac;
    Serial.print(buttonstate)
    // Print the flow rate for this second in litres / minute
    Serial.print("Flow rate: ");
    Serial.print(int(flowRate));
    // Print the integer part of the variable
    Serial.print(".");
    // Print the decimal point
    // turn on pin 3 if flowrate is greater than 4
    // Determine the fractional part. The 10 multiplier gives us 1 decimal place.
    frac = (flowRate - int(flowRate)) * 10;
    Serial.print(frac, DEC) ;
    // Print the fractional part of the variable
    Serial.print("L/min");
    // Print the number of litres flowed in this second
    Serial.print(" Current Liquid Flowing: ");
    // Output separator
    Serial.print(flowMilliLitres);
    Serial.print("mL/Sec");
    // Print the cumulative total of litres flowed since starting
    Serial.print(" Output Liquid Quantity: ");
    // Output separator
    Serial.print(totalMilliLitres);
    Serial.println("mL");
    // check if flow volume is > 1 litres
    if (totalMilliLitres > 1000)
    { digitalWrite(5, LOW);
      delay(5000);
      // reset volume to zero
    // Reset the pulse counter so we can start incrementing again
    pulseCount = 0;
    // Enable the interrupt again now that we’ve finished sending output
  if digitalRead(
/* Insterrupt
Service Routine
void pulseCounter()
  // Increment the pulse counter
  pulseCount++;
