Hello guys,
I made a custom machine to cut fabrics and I want a way to measure the fabric length.
Here are the solutions I came up with but every of them have its own issues.
I am looking for recommendations/workaround to make any of those work.
Resolution should be 1-2mm with a range of 0.5m - 4m
Use a gear with holes on the motor shaft with a hall or photo sensor.
the problem with this is that the fabric travels 20cm for each shaft rotation which means that if I use a secondary gear with 7cm diameter each 1mm on fabric the outer of the gear will be moved around 1mm which I guess is too small to work. Correct me if I am wrong. -
use a laser distance sensor.
I made a search and I found out that the sensor does not have a maximum of 4m range or the resolution is 1cm or the error is too much. I found some products with higher specs but the price is out of my budget.
Maybe I miss something? Maybe there is a sensor that I miss?
I would be very thankful for any advice.
