Measure frequency accurately on Arduino MICRO
Hello
I’m am trying to accurately measure the frequency of a pulse on an Arduino MICRO.
I have tried the frequmeasure library but I can’t make it work on the MICRO.
https://www.pjrc.com/teensy/td_libs_FreqMeasure.html
Do you see any alternative library that uses TIMER3 to measure frequency?
thanks
Post your code (between code tags), and what frequency are you trying to measure?
Hello;
I’m measuring a frequency of about 100Hz.
Sending a clean square signal on hte sensor pin it’s working fine fine with Arduino Nano, but nor on Arduino MICRO:
#include <FreqMeasure.h>
  Serial.begin(57600);
  FreqMeasure.begin();
  float frequency = FreqMeasure.countToFrequency(FreqMeasure.read());
  Serial.println(frequency);
Library can be found here: FreqMeasure Library, for Measuring Frequencies in the 0.1 to 1000 Hz range, or RPM Tachometer Applications
Note that I need to use TIMER3 on arduino MICRO, if you look in the .h it seems to be configured that way, but nothing detected on any pin.
THanks for your help.
