I want to measure the inference time of TensorFlow Lite implemented on a Microcontroller. I am beginner to TFLite and would be thankful if anyone can suggest me:
How can we determine/calculate the inference time of the TFlite? I mean where to initiate the timestamping in the C++ library of the TensorFlow Lite?
Is it possible to know how much layers are being used inside TFlite? and How to measure that what is the time consumed by each layer?
but where in the code I have to use this? as I don't know about the architecture of the TensorFlow Lite. and alos I don't know where in the code inference is called in the library. I am looking for architecture of TensorFlow lite, and find how inference is being done inside.
I am using Arduino Nano BLE 33 .
The code is attached.
// Import TensorFlow stuff
#include "TensorFlowLite.h"
#include "tensorflow/lite/experimental/micro/kernels/micro_ops.h"
#include "tensorflow/lite/experimental/micro/kernels/all_ops_resolver.h" //sajjad
//C:\Users\Sajjad\Documents\Arduino\libraries\Arduino_TensorFlowLite\src\tensorflow\lite\experimental\microfrontend\lib
#include "tensorflow/lite/experimental/micro/micro_error_reporter.h"
#include "tensorflow/lite/experimental/micro/micro_interpreter.h"
#include "tensorflow/lite/schema/schema_generated.h"
//#include "tensorflow/lite/experimental/micro/micro_mutable_op_resolver.h"
#include "tensorflow/lite/version.h"
// Our model
#include "sine_model.h"
// Figure out what's going on in our model
#define DEBUG 0
// Some settings
constexpr int led_pin = LED_BUILTIN;//2;
constexpr float pi = 3.14159265; // Some pi
constexpr float freq = 0.5; // Frequency (Hz) of sinewave
constexpr float period = (1 / freq) * (1000000); // Period (microseconds)
// TFLite globals, used for compatibility with Arduino-style sketches
namespace {
tflite::ErrorReporter* error_reporter = nullptr;
const tflite::Model* model = nullptr;
tflite::MicroInterpreter* interpreter = nullptr;
TfLiteTensor* model_input = nullptr;
TfLiteTensor* model_output = nullptr;
int inference_count = 0;
// Create an area of memory to use for input, output, and other TensorFlow
// arrays. You'll need to adjust this by combiling, running, and looking
// for errors.
constexpr int kTensorArenaSize = 2 * 1024;
uint8_t tensor_arena[kTensorArenaSize];
} // namespace
// Wait for Serial to connect
#if DEBUG
while(!Serial);
#endif
// Let's make an LED vary in brightness
pinMode(led_pin, OUTPUT);
// Set up logging (will report to Serial, even within TFLite functions)
static tflite::MicroErrorReporter micro_error_reporter;
error_reporter = µ_error_reporter;
// Map the model into a usable data structure
model = tflite::GetModel(sine_model);
//model = tflite::GetModel(sine_model1);//working from hellow_world
//model = tflite::GetModel(sine_model2);
if (model->version() != TFLITE_SCHEMA_VERSION) {
error_reporter->Report("Model version does not match Schema");
//while(1);
return;
// Pull in only needed operations (should match NN layers)
// Available ops:
// https://github.com/tensorflow/tensorflow/blob/master/tensorflow/lite/micro/kernels/micro_ops.h
//static tflite::ops::micro::AllOpsResolver micro_mutable_op_resolver;
static tflite::MicroMutableOpResolver micro_mutable_op_resolver; //sajjad
micro_mutable_op_resolver.AddBuiltin(
tflite::BuiltinOperator_FULLY_CONNECTED,
tflite::ops::micro::Register_FULLY_CONNECTED(),
1, 3);
// Build an interpreter to run the model
static tflite::MicroInterpreter static_interpreter(
model, micro_mutable_op_resolver, tensor_arena, kTensorArenaSize,
error_reporter);
interpreter = &static_interpreter;
// Allocate memory from the tensor_arena for the model's tensors
TfLiteStatus allocate_status = interpreter->AllocateTensors();
if (allocate_status != kTfLiteOk) {
error_reporter->Report("AllocateTensors() failed");
//while(1);
return;
// Assign model input and output buffers (tensors) to pointers
model_input = interpreter->input(0);
model_output = interpreter->output(0);
// Get information about the memory area to use for the model's input
// Supported data types:
// https://github.com/tensorflow/tensorflow/blob/master/tensorflow/lite/c/common.h#L226
#if DEBUG
Serial.print("Number of dimensions: ");
Serial.println(model_input->dims->size);
Serial.print("Dim 1 size: ");
Serial.println(model_input->dims->data[0]);
Serial.print("Dim 2 size: ");
Serial.println(model_input->dims->data[1]);
Serial.print("Input type: ");
Serial.println(model_input->type);
#endif
const int kInferencesPerCycle = 10000;
const float kXrange = 2.f * 3.14159265359f;
#if DEBUG
unsigned long start_timestamp = micros();
#endif
// Get current timestamp and modulo with period
unsigned long timestamp = micros();
timestamp = timestamp % (unsigned long)period;
// Calculate x value to feed to the model
float x_val = ((float)timestamp * 2 * pi) / period;
float position = static_cast<float>(inference_count) /
static_cast<float>(kInferencesPerCycle);
//float x_val = position * kXrange;
// Copy value to input buffer (tensor)
model_input->data.f[0] = x_val;
// Run inference
TfLiteStatus invoke_status = interpreter->Invoke();
if (invoke_status != kTfLiteOk) {
error_reporter->Report("Invoke failed on input: %f\n", x_val);
return;
// Read predicted y value from output buffer (tensor)
float y_val = model_output->data.f[0];
// Translate to a PWM LED brightness
int brightness = (int)(255 * y_val);
analogWrite(led_pin, brightness);
// Print value
//Serial.println(y_val);
error_reporter->Report("%d\n", brightness);
inference_count += 1;
if (inference_count >= 1000000) inference_count = 0;
#if DEBUG
Serial.print("Time for inference (us): ");
Serial.println(micros() - start_timestamp);
#endif
