is it possible to measure jitter on 3 different inputs signals?
I would like to enter this 3 signals on 3 inputs of timers.
(which ones?)
The signals are square periodics. period=2.5ms
I want a lsb of 0,1µs
I imagine to program the timers to start an interrupt and read the counter or something like that.
is it possible to have this 3 interrupts in the same software (the 3 signals won't be synchronous , it's impossible)
thank you
The Uno has only one such input, so won't handle 3 signals. A resolution of 100ns is well beyond any interrupt handler's capabilities, so it must be a hardware counter approach.
A set of 3 gated counter chips would do it.
If you want to measure jitter on both rising and falling edges that requires more complex logic.
There are hybrid approaches using analog electronics and voltage ramps but that's at least as complicated, and
better suited to handling timing differences between signals, not jitter.
